im looking to try either these or the turbines.. any suggestions?
Futuresonics Atrio M5
- Thread starter cn11
- Aug 9, 2006
ive not heard the new v2, but only the old v1 atrio. they remain my favourite universal iem. for a variety of reasons, they are simply solid: very good sq, great construction if not beautiful and a good cable from its makeup to connection fidelity.
they are not perfect in bass, mid or treble but hit hard at their price range and blow the whole industry to pieces when regarding build quality for the price. as a package, they are worth far more than the 200$ asking price which has a lot of rubbish players in the field in terms of build.
as far as sound versus the turbines, they have some similarities, but the turbine may have the edge in some areas. i think its inner construction has less echo problems though that does not mean you will prefer them.
if i had to choose one to keep, it would be the atrio, but i would miss the turbine very very much.
- Aug 9, 2006
this is double somehow...
ramintop
- Jan 22, 2008
not perfect in bass?!
NoLimits3D
- Jun 22, 2006
I believe there's a UK-based site that sells them.
Originally Posted by G-Ray /img/forum/go_quote.gif I really do miss my Atrios. I am kicking myself over selling them over a piffling fit problem. Should have tired the Shure black olives. The Comply's were no good for me at all. I loved the large stock foamies that came with the Atrios, they fit my ears perfectly without the need to compress them, but when it came time to replace them, I found out, to my dismay, that FS don't export its accessories outside the US. Soundstage - magnificent, mids - excellent, treble - perfect (not too bright and not overly dark either, a good balance), but the bass! Ineffably good, particularly when listening to bass heavy dance music. There was less than no need to amp them even when paired with my iPhone/iPod. I don't think I'll ever be that impressed by an IEM like that ever again. The only improvement that I would like to see would be a form factor conducive to side-sleeping with them on. |
Nirvana1000
- Jun 21, 2008
Do the Shure Olive tips match the sizes of the Atrio bi-flanges?So if the medium bi-flanges fit me then i should go for the medium olives right?And how do they feel and do they change the sound in any way?
PS.They aren't like the JVC Marshmallow tips are they?
Nirvana1000
- Jun 21, 2008
Well i just made custom tips(more like a mod to make fit) for my Atrios and they are super comfy and sound fantastic.I am using my favourite,most comfortable tips from my Sony MDR-EX082.And to make them fit because of the bigger hole,i cut the stem from the small stock bi-flanges and voila!They are a very comfortable fit and sound awesome!
Update! Those of you who have these Sony Tips,i highly recommend you try this.Great isolation and so comfortable you forget your wearing them!
G-Ray
- May 24, 2009
Too late was the cry, unless I could do a swap with my UE Super fi 5 vi's for another pair of Atrios.
Can't see that happening hehe.
Originally Posted by NoLimits I believe there's a UK-based site that sells them. |
G-Ray
- May 24, 2009
Pardon me, duplicate post.
- Aug 9, 2006
by not-perfect bass, i was referring to the echo problem that i and a very small handful of members encounter. it has less to do with the headfi community as a whole as most people listen to slower music like rock or jazz that is not bass-driven.
i am a trancehead, so thrive on perfectly engineered speedy bass with no harsh echo. the atrio remain my favourite universal iems - but they simply do not do trance the way i need.
G-Ray
- May 24, 2009
^ I'm intrigued. When you say "trance," are you referring to uplifting trance or psy trance? I am curious because while listening to the former, I didn't really notice said bass echo.
Then again I'm not quite an audiophile, just a wannabe audiophile.
ethan961
Member of the Trade: Bugden Audio
- Mar 16, 2008
Well, my atrios broke today - the nozzle part with the blue ring came off. It is glued to the rest of the phone where the blue ring is. A small amount of superglue was applied (it came cleanly off, looks like the glue just loosened. When it was open, I noticed no difference in SQ with the tip backed by open air and the tip attatched to the rest of the IEM.
However, seeing as this looks like a good place to disassemble them, they come apart so as to allow a recabling job, which is good for out of warrenty people experiencing the eventual cable hardning after years of hard use.
EDIT: I forgot to mention, the driver is located in the tip section, allowing for easy wire access.
- Aug 9, 2006
i listen mostly to just normal trance club stuff. like armin, markus schulz etc. i used to be into psy and psychedelic. the echo i am talking about is in the high energy bass: upper mid to upper bass and low mids. if it does not bother you then that is great. it has bothered me on many earphones i have owned: very much.
Nirvana1000
- Jun 21, 2008
Holy crap!I didn't think the Atrio's could pull it off,but they did!Listen to the second "crazy bass test" sample.Just like full sized headphones!Impressive!.Crazy Bass Test | Bass Test, Woofer Test, Subwoofer Test
PS.Turn off all bass enhancers and other effects on your sound card before you listen.And start with low volume.
Nirvana1000
- Jun 21, 2008
Here are some other good ones!Woofer & Bass Test : Stealth Settings
Warning!Pure Bass!http://www.wooferbasstest.com/bass-o...ofer-test.html
Total: 11 (members: 0, guests: 11)
