dakanao
- Jun 8, 2012
Is the transient impact smoother than with cups, due to no back resonance?Look ma no cups!
Underdamped for Shure.
Negative and positive. Smoother if you mean less dynamic and less quick. Smoother frequency response minus bloated bass. Trade off. I had been using TRX00 with TH500RP open cups previously. No cups sounds same as TH500RP cups before I added damping mods…Is the transient impact smoother than with cups, due to no back resonance?
Usually people use the attenuation ring to get the bass back. I can confirm you definitely get more bass but I don't remember much about the treble.Has anyone has experience using TH-X00 mahogany with authentic Th900 pads and dekoni attenuation rings?
I love the comfort of the 900 pads but they make the treble super fatiguing. Do the rings help?
Yes I've tried like 10+ pads nothing beats stock pads (in terms of sound).The time is rapidly approaching when I will need to replace my stock pads, which truth be told have NOT worn very well.
The outer layer of the pads has not proven to be very durable and is flaking.
Million dollar question is where to find stock pads??
I don't want anything else other than stock, for all the reasons enumerated in many threads on the subject.
Any advice would be most appreciated!
At this stage I am (almost) prepared to buy another headphone just for the pads...![]()
LOL now looking back a lot of the info are kind of old since I wrote them so long ago.@Hyde00 Thanks for the link to your excellent article, most informative indeed!
And yes, I will gladly buy your spare pair if the numbers make sense.
Challenge will be shipping from Toronto to Cape Town I suppose, but where there's a will...
I will PM a little later today.
Hey thank you for the reply! I've tried some of them before and I believe they're the same as pads from AHG. So some are TH-X00/E-Mu Teak pads (10 cm diameter) some are actually ZMF pads (11 cm diameter).I just bumped into these very cheap pads - it's $10 incl. shipping for me. Anyhow, if this can help anyone (and maybe you get a $1 off and I get a $1 off, or just choose the right poison and shop directly.
Leather - Perf - multiple variants.
Your US $1.00, My US$ 1.00 in coupons are here!
https://a.aliexpress.com/_m0SNGWC
Yes that's correct. But these must all be 10cm, I've bought a couple now, all are 10cm. Fit my EMU and Hifimans fine.Hey thank you for the reply! I've tried some of them before and I believe they're the same as pads from AHG. So some are TH-X00/E-Mu Teak pads (10 cm diameter) some are actually ZMF pads (11 cm diameter).
They're not bad but maybe I was picky so I was looking for identical sound.
But for anyone that's not super picky like me they're actually not too bad haha.
lol I know eh? I don't know why they're so expensive and they're actually just protein leather too. Like I bought official TH610 and TH900 pads a while back and it cost me an arm and leg.Yes that's correct. But these must all be 10cm, I've bought a couple now, all are 10cm. Fit my EMU and Hifimans fine.
The real OG pads are... quite hard to find nowadays. And stupidly priced while they're not even real leather.
Thanks for this great post! Just checking to see whether the $17 pads have held up well and if you still like them. Just ordered some Fostex X00 Ebony HPs and was about to pull the trigger on Dekonis when I saw your post and measurements. Thanks!Well, I received the pads yesterday. Yep, real leather and memory foam. Incredibly soft and so comfortable! Very good build quality, too, especially for the price. They are thicker and have a larger ear hole compared to the stock pads.
Measurements:
Thickness: ~31mm (Back), ~20mm (Front)
Earhole: 67x45mm
Diameter: 105mm
Width (around the earhole): 33mm (Back), 23mm (Front), 17mm (Top and Bottom)
Dimensionabley, they are similar to the knock off Dekoni hybrid pads I was using except with a much larger earhole (58x38mm on the Dekoni-like).
Pictures side-by-side with the stock pads:
Profile
I also took some measurements to see how they compared (non-standard homemade measurement rig, don't compare to anything else and take with grain of salt).
In a word: BASS!
If you liked to listen to your stock X00s with an EQ bass boost, these are the pads for you! They don't harsh up the treble (*cough*ori pads*cough*) or wreck the midrange (I'm looking at you, Dekoni knock-offs...), but just add some really nice heft to the low end. This is honestly how I thought my Purplehearts would sound when I bought them. Keep in mind this measurement is without an attenuation ring on the sheepskin pads (more on that later).
I also compared them to my Dekoni-like knock-offs.
A little more bass (but, keep in mind, this is will full 3D printed attenuation rings on the hybrids and none on the sheepskin) but they really bring the scooped out midrange back (300hz-2khz), which has always annoyed me about those hybrid pads.
And here is with and without attenuation ring compared to stock
That bass is just madness! More than a 10db boost over stock!Too much for me, but if you really like to crank that EQ with other pads, the attenuation rings might be fun for you.
I've been using them without the attenuation rings and I have been enjoying them a lot. Even with the boosted bass, it's still clean for a dynamic (my HE6se V2 has been spoiling me for tight and punchy bass) and not boomy/bleeding. This is honestly what I wanted from them all along, boosted bass, smooth midrange, and a little top end sparkle for fun listening. For $17 shipped, these are a killer deal for the comfort alone, if nothing else.
Anyway, I hope this was helpful to anyone who was on the fence about these. Stay safe and happy listening!![]()
Yes! The pads are still great and I'm still loving the sound, exactly the sound profile I wanted from my purple hearts. Made a headphone that I rarely listen to and made it one of my faves in my collection for bassy music and video games/movies.Thanks for this great post! Just checking to see whether the $17 pads have held up well and if you still like them. Just ordered some Fostex X00 Ebony HPs and was about to pull the trigger on Dekonis when I saw your post and measurements. Thanks!
