bavinck
- Feb 12, 2014
There is a gap between the wood cups and the frame. Seal it up by making a foam ring or tape it up, and your isolation will increase by a lot.
Wouldnt that kill the bass?
My stock pads are getting quite comfortable, they were a little stiff out of the box.... agree on the rotation/position being quite important.
These pads were made for the thX00. Clearly, it is going to be difficult to replace them as they were created to get the sound just as it is. I think people should really give them a chance. They really are not as bad as people are saying, I'm surprised by it frankly as I like them.
They remind me very much of the denon pads and people didn't seem to be complaining much about those.
As for the pads, I've found that as long as you tuck the back of your ear inside the pad opening, the muddiness goes away and the headphone really shines. This is not as difficult as it sounds. Simply move the headphone back a bit further than you're used to, making sure the back of your ears get captured by the pad opening. Then you can push them forward for a comfortable fit. Just putting them on your head without attention to the fit leads to an on-ear condition with a bunch of that wide portion of the pad out in the air behind your ears. I don't think the pads were designed to fit that way.
This is awkward. I don't have a 6.3mm jack, only a 3.5mm, so I guess I'll be heading off to the electronics store tomorrow.
It's a bad adapter, i recommend even a radioshack brand. Or better yet a custom one with a short cable.
There should be a Monoprice adapter in the Massdrop (not the Fostex) box loose in a small bag.
I don't know if it's a bad adapter, but physically it's awkward. I'm using a sennheiser adapter that has a short cable between the 1/8 and 1/4 ends. Flexible and practical. About $15
http://www.amazon.com/Cable-Adapter-Female-6-3mm-3-5mm/dp/B008JGWY2Y/ref=sr_1_2?ie=UTF8&qid=1449891130&sr=8-2&keywords=sennheiser+adapter
Thanks for that, I'll go take a look!
If that's so, I guess I'll still being going out. Thanks to you both!
