I think my pair sounds significantly better off of my Burson Soloist 3XP than my cheaper gear. The 900’s have sounded “good” off of all my sources, but the extra quality power really makes them better in all aspects, I think.Do these scale well or is it fine to just throw an Asgard3 at them and call it a day?
I've been searching for a headphone and my favorite I have ever owned was the TR-X00 PH which died due to gimbal failing. So.. I kinda had it in my mind I wouldn't try to TH-900 MK2 because of this. I think I was wrong to do this as I'm wondering if the TH-900 was the one I've been looking for all along.
Fostex TH900 MkII
- Thread starter iBrian
- Tags
- fostex-th-900
They scale, but I think they're more amp dependent than DAC dependent. I find a good tube amp works best.Do these scale well or is it fine to just throw an Asgard3 at them and call it a day?
BenF
- Jan 22, 2013
They are ridiculously easy to drive, so practically any amp will do, as long as it doesn't have a warm tilt.Do these scale well or is it fine to just throw an Asgard3 at them and call it a day?
IME these phones do scale with better amps and DACs. The more you give them the more they can offer you. My amp progression while also owning TH900mk2 & TH909 was Jot 2 & Liquid Platinum to Violectric V281 and DACs, Bifrost 2 to Soekris dac1541 and most recently I added a Holo Spring 3. With that said I was extremely happy with them working off the Jot 2 & Liquid Platinum and Bifrost 2 - there was not a need to upgrade those components for the headphones specifically. The updates I made to my source were just that, me updating my sources. The TH9xx's I have just happened to benefit as a result.
Also, sometimes drivers die, components fail. It happens. It's not necessarily a reason to avoid a specific brand/type, unless the failures are disproportionately wide spread, and that could even be due to a bad batch etc.
Huntersknoll
I know, I was just heart broken. I loved my PHs lol. They got me into audio. The TH-900 would be a good way to honor them.IME these phones do scale with better amps and DACs. The more you give them the more they can offer you. My amp progression was Jot 2 & Liquid Platinum to Violectric V281 and DACs, Bifrost 2 to Soekris dac1541 and most recently I added a Holo Spring 3. With that said I was extremely happy with them working off the Jot 2 & Liquid Platinum and Bifrost 2 - there was not a need to upgrade those components for the headphones specifically. The updates I made to my source were just that, me updating my sources. The TH9xx's I have just happened to benefit as a result.
Thanks all for the input! Yeah I was looking at a some burson stuff and the jot2. There is a lot of fun in just researching new gear
I have my 900 and use them on Woo WA5 LE which is a big tube amp. I find the 900 strange for closed back headphones. It doesn't sound closed in. There is depth like my open back headphones. The 900 separation is top notch for edm. So like my 1266 these I couldn't sell.
marcus2704
- Apr 13, 2016
I have received these and am impressed so far. Running off the 6.35mm port on my IFI Diablo and they sound great.
Should I be looking at a cable replacement with balanced connector for these?
jmills8
Previously known as bmiamihk, jmills2
NoI have received these and am impressed so far. Running off the 6.35mm port on my IFI Diablo and they sound great.
Balanced connector isn't needed but as far as I can see Diablo isn't some insanely powerful source. I have three different cables for my TH900mk2 and I can tell you that - they do react to different cables. If you're feeling like changing/tuning their tonality more to your liking, then go ahead. I find the stock cable to make their bass too loose and the lower treble far to bright to sound natural. Astral Acoustics SSPC cable does wonders with TH900 increasing bass control and resolution and taming the treble peak but keeping them quite bright still, which brings forth the midrange without actually making them sound more in-your-face. Besides they sound way more holographic and the soundstage improves by quite a bit, showing some depth at last. On stock it's wide but damn flat.I have received these and am impressed so far. Running off the 6.35mm port on my IFI Diablo and they sound great.
P.S. Listening with both Aune S6Pro and Burson C3X Performance.
Which version of the Astral Acoustics cable do you have?Balanced connector isn't needed but as far as I can see Diablo isn't some insanely powerful source. I have three different cables for my TH900mk2 and I can tell you that - they do react to different cables. If you're feeling like changing/tuning their tonality more to your liking, then go ahead. I find the stock cable to make their bass too loose and the lower treble far to bright to sound natural. Astral Acoustics SSPC cable does wonders with TH900 increasing bass control and resolution and taming the treble peak but keeping them quite bright still, which brings forth the midrange without actually making them sound more in-your-face. Besides they sound way more holographic and the soundstage improves by quite a bit, showing some depth at last. On stock it's wide but damn flat.
SSPC - it's in the "Wire supplies" section if you're curious. When I asked for a cable that would be neutral in terms of sound signature but at the same time transparent and with good technicalities, that's what they suggested as the perfect option and I think it was a great recommendation. I love the cable, it's looks and build. Wasn't cheap but if you ask me, it was worth every penny.Which version of the Astral Acoustics cable do you have?
It is a great looking cable. All their cables look great looking at their lineup.SSPC - it's in the "Wire supplies" section if you're curious. When I asked for a cable that would be neutral in terms of sound signature but at the same time transparent and with good technicalities, that's what they suggested as the perfect option and I think it was a great recommendation. I love the cable, it's looks and build. Wasn't cheap but if you ask me, it was worth every penny.
I have two other cables fro mAstral Acoustics, but for IEMs. Their line-up underwent a revamp some time ago though and now they offer much more high-quality cablesIt is a great looking cable. All their cables look great looking at their lineup.
Most of their cables seem to be for IEM’s. I take it your cable is a special order?I have two other cables fro mAstral Acoustics, but for IEMs. Their line-up underwent a revamp some time ago though and now they offer much more high-quality cables
marcus2704
- Apr 13, 2016
Is the Hugo 2 a good pairing for the Fostex TH900 MKII?
I don't need a transportable Amp/Dac however, should I be considering anything else at that price point?
