CongoFather
Ifi Micro idsd Black, Ibasso Dx200 amp3(probably also amp8), Chord Hugo v1 are good matches that I have tried. The ones I do not recommend are Chord Mojo and Cayin N5ii.
So I'm probably going to buy a TH-900 Mk2 sometime in the near future. I actually just decided to cancel a TR-X00 Mahogany order because I knew that I'd always wonder about the TH-900 bass...
Regardless, I was wondering what you guys would think would be better for taming the TH-900 highs? Adding 610 pads? Buying a Schiit Loki?
Any recommendations?
I'm using a Violectric V100 amplifier by the way.
The 900Mk2 is on Sonarworks list of tested headphones. If anyone is using SW with the Fostex TH900MK2...please chime in.So I'm probably going to buy a TH-900 Mk2 sometime in the near future. I actually just decided to cancel a TR-X00 Mahogany order because I knew that I'd always wonder about the TH-900 bass...
https://dekoniaudio.com/product/dekoni-audio-fostex-th900-fenestrated-sheepskin-ear-pad-set/I've bought some as new ones yesterday off eBay. Can't wait for them to arrive, always wanted some. I have some purple hearts and looking forward to hearing if they are better. Going to use them with my Cayin n8
Think you can try it on the PH. It gives a more open sound , vocals upfront with this pad.More comfortable?
Jvc10000 iemHas anybody found portable headphones that sound close to these wonderful cans?
Very hard to get in the UK. I'm back on the porta pros this morning!Jvc10000 iem
