ReaperZzZ
- Aug 8, 2012
Perfect, thank you !! I've emailed a couple of local electronic retailers here in New Zealand to see if they can supply the same thing, otherwise I'll just order those.The SMC jacks that fit without mods to the cups, baffle or frame of the TH900: https://vetco.net/products/smc-female-chassis-mount-connector/pan-smc-2963
That cable looks awesome ! As my SZ2000's cable was 1.2m , that's the perfect length for me, time to track some down with a 3.5mm plug rather than the 6.3mm plug.. that image looks like it's 3.5mm actually, i'll message the seller!For cables you can use any cable that is terminated with SMC jacks like this: https://www.ebay.com/itm/1-2m-4ft-High-Quality-Audio-Upgrade-Cable-for-Hifiman-He-5-He-6-He-400-He-500-He/391853920891?
