So is this bass rattle problem a thing that develops over time? I've had my pair for a few months now with no trouble and I'm hoping I didn't make a bad purchase... They sound fantastic with a balanced cable on my Jotunheim (I listen mostly to dark prog rock so not super bassy).annoying, my pair has a bit that issue to, in the right cup but only on heavy bass songs, i did noticed just a couple of times so far....
Fostex T60RP
- Thread starter Sopp
StalkerRus
- Mar 10, 2012
Hi! Two quick questions:
- How much sound do those headphones leak? I had a plan to use them in the open-plan office and I don't want to bother my colleagues.
- Will I be able to drive those properly with Fiio Q5?
sbtourist
My two pairs were faulty straight away, to properly test them use the Bass Shaker here: https://www.audiocheck.net/soundtests_headphones.php
Good morning. I have a spare pair of zmf oval lamb pads. Would I benefit by putting these on my t60 rp headphones. Thanks.
- Sep 28, 2016
Dude, if you have spares, just try them to see for yourself, no one can say that it improves sound for you as everyone hears differentlyGood morning. I have a spare pair of zmf oval lamb pads. Would I benefit by putting these on my t60 rp headphones. Thanks.
selvakumar
That's why i ordered MODHOUSEAUDIO ARGON MK3 with balanced mod all perfectBoth drivers are rattling a lot, especially the left one. My T50-RP mk3 has a bit of rattle only at 30Hz sinewave and for volume higher than 80dBFS (measured with DecibelX in the middle of the driver).
I'll see if I can fix it. I think the rattle seems to be caused by imperfect alignment of both halves containing the magnets, but I'll update the forum when I'll have some results.
Couple of close-up pics, not related to the rattling issues.
upgrade pads that doesn't break the bank for the T60RP ?? i'm located in europe....
A strange question. My left ear is not quite as good as the right. The soundstage is a little to the right on my T50RP and T60RP headphones. Anyone have any ideas how I can sort it. Thanks.
Balance control?
Unfortunately I don’t have any on my amp.
Thanks!
Sound leakage is quite moderate based on my testing. I guess it depends on your co-workers whether they would find it annoying. What are you currently using?
Brainwavz (Angled) Oval Sheepskin
I use these pads. They are very good on mine.Brainwavz (Angled) Oval Sheepskin
Yeah. Stitching might be a bit rough visually on Brainwavz pads, but otherwise a great sounding option.
i use at the moment brainwavz angled hybrid, not happy at all ! i will give a try to the sheepskin version, by the way has to be an xl version or a regular one is fine ?Brainwavz (Angled) Oval Sheepskin
