FQUOTE="ttran946, post: 14642158, member: 456448"]I can't wait to hear your more detailed description of your mods.
Which ZMF pads did you end up with? I actually just took my ZMF pads back off and replaced it with the stock pads. The ZMFs are so comfy, but I thought they really degraded the sound quality quite a bit. I had to open up all the bass vents and even had to take out the stock baffle ring that came in the headphones in order to reduce the bass to a point where it wasn't boomy and uncontrolled, although even with this is sounded a little uncontrolled. I also felt like the overall sound quality in terms of resolution and precision was decreased by moving the driver so far away from my ear with the ZMF. I feel like Fostex wanted these to be detailed with good resolution for the price range and they knew they had to put the driver as close to your ear as possible to achieve this with the small driver. I was considering trying to add some cotton to the inside of the cups to use with the pads to try to get the bass situation under control. I really wish I liked the sound with the pads more as they look amazing and are like pillows. That being said, if you have a big head the clamping is much stronger because of the thicker pads which could make these uncomfortable for some. I don't know if I could recommend the ZMF pads without figuring out some additional mods to retain sound quality with them.
I am beginning to suspect that something may be wrong here. I say this because you may be the only one that finds the bass totally
out of control and bleeding into the mids. I have all the ZMF pads and none of them is causing problems, not even when
used on the T20 RP MkIII. Could it be that your ears are not going all the way inside the pads next to the driver? ZMF pads
increase both soundstage and bass. Is this your only pair? could it be damaged? Your complaints are not in agreement with
your review on the 2nd week you had them when you wrote it. But because you like the Hifiman there is also the possibility you
listen differently than me. Hifiman has a model of the week in their effort to figure out how to get the midrange right and they keep
trying. Many people like them and it is very natural that these people would not like the Fostex.
What kind of music are you listening to? are you a musician? do you like the Senns? what is behind them in the line to your source
( amp, DAC, purifier) are you optically or USB connected to the source, there are so many parameters,
how often to do you attend live performances?
Have you read my post on how to listen to the music and the other 9 or 10 clips that this man made on how to listen to the music?
I don't know what to say, there was another member here and we became friends that did not like the T60 but he did not have such
a serious problem with the bass. The most probable thing is bad drivers but even this, I have yet to see a Fostex fail and every day
I hear of failures on the other guys. I just don't know what is causing the problem with the bass.
Mr.Speakers, Smeggy, Zack (ZMF), Mod house (Argon), Mayflower, LFF, Talos all started a successful business using RP's not to mention
Headfonia that is raving about them, even though they sell Audigy and Hifiman (can't make money from a 150 $ set).
As far as my feature mods are concerned you will not like them because they will retain the RP (regular phase) singature of the
Fostex which is absolutely what made them famous and popular and no other manufacturer has tried to duplicate
(more on that at a later post).[/QUOTE]
I disagree with you pretty much entirely. You seem to keep assuming I don't have experience (offering your videos haha, which I did watch just to amuse myself) but your assumption is wrong. I pretty much have ran every genre through these cans for extended hours of listening thus far. I compared them specifically to HiFi man because they are the same price and both planar. I have other headphones/monitors/speakers to reference as well.
You also seem to assume that I don't like them. Which I do. The bass is in control without any mods (or with the bass vent mod) it just doesn't have the volume and detail as I would like. I want others to know if that is what they are looking for to shop somewhere else.
I am saying ZMF degrades the overall sound quality as I hear it. You are getting offended as if you are making money off of the sales haha. That is my experience, as you know everyone hears and perceives differently. When I am saying it is out of control I am basing it on other head to head comparisons coming through my same rig. I know when precision and accuracy is lost when I make a change compared to when I have not in every post I have made and that is what I am reporting hearing. Honestly some of the mods you recommended like the Mayflower ring is a blatantly terrible suggestions as any fool can hear how poorly it sounds afterwards. I am waiting to see if someone else chimes in on this mod at which point I could stand to be corrected if someone somehow would find that pleasurable despite what I am sure is actually a measurable loss in sound quality. The additional suggestion of pealing the gray part off of the back of the ring suggest you don't even understand how the mod works, as it pretty much only has to do with the bass vents.
It's important to report my experience even if it is negative as not doing so is exactly how you get run away gloat fests on forums about headphones and people spending money on unnecessary mods that only hinder their sound quality or buying a pair of cans they don't like because they only see the good side of things. I like to weight the negatives with the positives when I do a review of something which I think I have done fairly in every post. No need to to my experience personally though, as it is just like my opinion...man.
