kintsaki
Hey man, any luck with the Greek Fostex distributor? Have you come to contact with anyone? Learned anything?
I am really eyeing the T60rp at the moment. I was debating getting the T50rp and then modding them over time, but man does the wood make them look glorious. And I think they sound just as glorious as they look. However, Greece is again left out of the game. Although this time it looks that they are not available in Europe anyway, and general availability is scarce anyway. Maybe they're too new?
Then again, I only have a Fiio Q1 1st gen and I highly doubt I'm gonna get even close to 100% out of an RP headphone, so maybe I should get a better amp and then budget out for a T60rp after the summer...
The Greek distributor will bring them in 6 months. I got them from Amazon UK.
They have new drivers that are more powerful more sensitive and extend both
higher and lower than the MK III even though the specs remain the same.
They are worth every penny due to the improved drivers.
There are 3 modes to make them killers (They all apply to MK II's and III's I tried them)
1) Removal of hard felt and replacement with soft (That is to increase bass like going from T50 to T20)
add surgical mask cloth and transparent linen material to fine tune treble externally on the 3 slot openings.
2) ZMF pads (forget the Shure pads that Zeos pushes.)
3) Make and place a 10 mm thick wood oval ring between cap
and baffle to increase the volume of the enclosure and achieve bass and maximum
output equal to or better than LCD2 without the shouting AND shrilling DRY mids and trebles of Audezes, Mr. Speakers and Hifimans.
You may have to add some cotton felt to fine tune to your taste.
When you are done you will be shivering on both sides from your shoulders to your knees on your favorite music for more than 20 minutes.
A reviewer calls them flat and perfect for studio monitors but not for music enjoyment.
(That is another moron or money grabber that does not know (WTFHITA) like that guy with the wall of fame that has no Foster on it).
I may not be posting for a while (will be enjoying music). If your source is a computer whatever you do buy an ifi USB 3.0 Nano otherwise you are
plain old low fi. And make sure you can push 3 watts into 50 ohms (Audio Trends will do that for 125 $) ifiusb3.0 at 225$ for a total of 350$ will
destroy ifi Micro DSD because the integrated purifier is still low fi if you want hifi buy USB 3.0 nano and later when you have money get an expensive
amp.
