A_Man_Eating_Duck
- Dec 19, 2007
It more meant about the wording Matvei used. To say the supplied power cable is garbage is a massive exaggeration.
Well it's an audio forum so you can see where the confusion is when you call something garbage.
Good to have that cleared up.
EDIT: Since you're buying the Japan version, it's normal to get a cable without a ground pin because Japan power sockets only accept 2 pronged power plugs.
http://www.japan-guide.com/e/e2225.html
You should be able to get it much cheaper if you follow Matvei's advice.
http://www.head-fi.org/t/578167/fostex-hp-a8-dac-amp-and-other-fostex-gear/210#post_10332935
Ya if both HP-A8 and HP-A8C are the same make sense to just buy the Japanese version and tweak it.
I might just buy the deal package from Sonic Sense for $2295 USD as I need the second TH900 for work.
