Thanks, but I've already blown my powder on that RCA tube, so I'll have to patiently wait till next month to try again. Please give me/us some guidance as to what to look for when they do publish measurement results, but don't provide all of the reference values I need to compare for making the purchase decision.
I saw that Sylvania pair, but why don't they list the normal "new/NIB" result as well as the "minimum" so we can tell where on the continuum of values this tube sits? I care about the normal "New" value far more than the failure value. Without both end points as references it isn't possible to know where the results fall in the range of Worn out, to Used, to New.
When I see those results they look to me as in the 82% range of life left, which would be lower than the one I posted, and not acceptable to me, so I passed right by them.
"Condition:--
2 NIB RCA 6AS7G Tubes,pair USA Sylvania branded manufacture--TV7 tested-test nil for shorts
TV7 tested : 36/36 is minimum
TEST : 82/82 and 82/80"
I hear 65% of new result is when to change a tube, but working backwards a 65% value of 55 would be 36, so is 55 the "new" 100% reading? That would mean a 122% value would be about 67... so 82 is 150% of new? What it the 36 value is 50% instead of 65% as the "replace" reference value? That would make 82 114% of "new"...
That's why knowing the actual out of box "New" result would make this much easier - and why the 36 "minimum" as the only reference value doesn't really help.
When comparing the single TV7 measurement result against nothing but a minimum, vs the abundance of Amplitrex A1000 results are like comparing Apples and Pogo Sticks to me, without an existing reference to shoot for how are we supposed to judge the listed results?
I asked the guy with the RCA tube above and he said normal new was 5800 uMhos and this was the highest reading tube he had in inventory - I asked him the month before to find such a tube - and he followed through and contacted me, so I asked him to list it to purchase and he didn't jack up the price over the tubes with lower test results - so to me his follow through counted as much as the test results.
Comparing only the uMhos results - to my thinking - makes those 5040uMhos/5020uMhos results showing about 85%, or is that also not the correct way to look at it? What about the other measurement results from the A1000?, which test values do we weigh as higher in usefulness to consider when deciding which available tube to try?
What is the expected "new" value for the RCA 6AS7G on the TV7?, and what values from the Amplitrex A1000 output should I be using to judge the value of the tube under test?
Thanks again for the helpful guidance.
Update: Ah, so perhaps my "guesstimate" was close? 100 would be actually 100mA on the meter showing a 100% result, and so then 82mA would therefore be "82%"?
https://www.head-fi.org/threads/for-6as7g-tube-rollers-here.410326/post-16212445
https://www.head-fi.org/threads/for-6as7g-tube-rollers-here.410326/post-16212525
And, the Amplitrex printout also printed the mAdc "meter" readings: 105.6mAdc / 89.6mAdc if on the same 100mAdc = 100% scale that would be 105%/90%?, also the highest of that value for all the RCA 6AS7G tubes he has listed, so perhaps I overpaid, but I also got a "newish" tube? In a more perfect field of available choices I would have liked to hold out for 100%+/100%+ instead of the uneven result.
So then how much does looking for the highest uMhos readings play in choosing? As he said the uMhos value of 5800 is considered on the Amplitrex as "new". And, what about the Mu value?, how much does that matter? 1.5Mu isn't the lowest, I've seen 1.7 to 2.0, shouldn't a new tube hit all the "numbers"? Lower results in each section must mean some particular correlation with use/age? Or is that normal variation and "matching pairs/quads" involves judging how the results of each tube fit with the others in the set?
Checking the AT1000 manual, there is a provided "CDROM' with the TUBEDATAxxx.CSV file and tools to read/edit the data and upload it to the tester:
https://amplitrex.com/wp-content/uploads/2017/12/AT1000-Manual.pdf
https://amplitrex.com/included-software/
And, the same for the TV7 I assume, and I've seen little green data cards for each tube to push onto the tester to make the settings.
Without access to that proprietary to each tester information, how are we to tell if the published/listed test results are what we think they are?
Sorry for the long post, lots of items I am learning at the same time, and trying to fit them together.
Any tips/hints/links to set me on the right path? How about an online copy of the Tube data / results tables for the AT1000/TV7?
