Dogmatrix
- Apr 1, 2011
Could be small pieces of glass from the manufacturing process if so its not a problem in useI have just received my first pair of TungSol 5998. Please excuse the noob question however they make a lot of noise if I tilt them up and down and move them around in my hand. I approached the seller regarding this and was told it is normal for the 5998. One tube is significantly noisier than the other. Do other 5998 owners experience this same behaviour? I have not put them in the amp yet for fear of damaging something.
Thanks in advance.
Could be the heater elements , heaters have something of a reputation for arcing in the 5998 some in our community will not use them for that reason
Not to say that if they rattle they will definitely arc , they probably wont
If you have an OTL it is safe to run with no headphone attached , transformer coupled amps not so much I use a pair of $10 cans for this
Best practice with all new tubes is to switch on without headphones attached and be ready to switch off if anything dramatic happens , if they survive the first five minutes they are likely fine
Your amp will likely survive an arc but headphone drivers often don't
