Like Roomwizard EQ?
For eq i just use equalizer apo and the program(out of your head) is virtual surround/loudspeakers, its free to try and there are demos you can listen to in the website( fongaudio.com ).
Like Roomwizard EQ?
And yeah, I know about the Harmann Response Curve. I have it EQ'd so it will sound non-Harmann neutral, which, to some ears, is bright, but nowhere near as bright as Grados. When it gets too bright, IME you begin to lose detail again, and clarity plummets, so I understand what you're getting at.
Nice, I'm using Peace (EQ APO plugin) for online stuff, and a Kjaerhus Audio GEQ-7 VST for Foobar.For eq i just use equalizer apo and the program(out of your head) is virtual surround/loudspeakers, its free to try and there are demos you can listen to in the website( fongaudio.com ).
Im pretty sure I'm a broken record, but if you liked dolby headphone give Out of Your Head a try, same principle but better.
If any of us could afford Smyth realizers, we already have them. I tried Out Of Your Head, but it wouldn't run properly. There was some sort of error with one of the drivers, I believe.
