Gadget67
- May 28, 2012
I’m looking forward to your comments!I'll let you know in six weeks.
Which Lazuli cable do you recommend for the Utopia? When I went to the website there were about 5 different versions.
Also, does anyone have experience of buying from the UK? Vinh has been in contact with me but I assume there will be customs charges as well.
Thanks
The Lazuli Reference seems to be the popular choice. Here is a review of the Nirvana (their most expensive choice) from Audio Bacon. Have fun deciding...Which Lazuli cable do you recommend for the Utopia? When I went to the website there were about 5 different versions.
Thanks
I got the Lazuli Reference on Monday, and I'm a bit less than halfway through break-in time of 100 hours or so. So far, so good!Which Lazuli cable do you recommend for the Utopia? When I went to the website there were about 5 different versions.
Thanks
Great that you are off to a positive start. No buyer remorse then?I got the Lazuli Reference on Monday, and I'm a bit less than halfway through break-in time of 100 hours or so. So far, so good!
Good for you!! I've been using that as my DAC for about a month or so, and so far, I've just left it 'as is', with none of those many, many sound processing adjustments available on it, and I think it sounds GREAT! In fact, I replaced the Hugo 2 in my setup with this, which I like better and is a lot less expensive. Got that signal running into a Quicksilver Audio tube headphone amp, and we got some serious sounds! Later this week I'm expecting to receive a couple of tubes for upgrading the amp (didn't figure ones that came in a plain white box and just said 'China' on them were of the top-most quality; contacted Brent Jessee for buying replacements).Utopias new Buddy
Cool! Let us know how you like that. And that should also shorten up the time for reading the instruction book....I won't use the DSP. I prefer the Neutron Player. There I use the equalizer to adjust the Utopia to Oratory's Hamann curve. I will not connect an external amplifier
I don't know how well it would pair, but you could do a lot worse than at least looking into that RME DAC; might not be what you're looking for, but it's a pretty fascinating piece of gear from a German company that primarily makes equipment for professional recording studios, and it shows....So with my MHA200 on order anyone got a recommendation for a good dac to pair? I'd prefer something with USB c or normal usb input so I could hook up my android device to it via USB Audio like I do with the WA11.
That’s a hard question to answer until the MHA200 is out in the wild and there is some feedback or review to use as a guidepost.So with my MHA200 on order anyone got a recommendation for a good dac to pair? I'd prefer something with USB c or normal usb input so I could hook up my android device to it via USB Audio like I do with the WA11.
