MACyaner
Hello up late,are you saying that you listened to these different utopia's on different rigs? if so, then you have introduced variables into your headphone comparisons. unless you are comparing the units side by side on the same rig, then not only are you relying on your memory of how the units sounded, which is fallible, you might also be mistakenly attributing the differences you hear to the headphones while not allowing for the possibility that the different rigs they were paired with could have affected the sound.
your assertion that 'these sound differences are normal' is unsubstantiated. and as the 'high-end devices' that you refer to reproduce sound rather than measure it, i am going to assume that your claims are based on your aural perception rather than headphone measurements. as i posted previously, your subjective experience with different utopia units doesn't align with my own.
yes, focal replaces both drivers with a matched pair but it doesn't necessarily follow that this would perceptibly change the sound of the headphone as a consequence.
again: the tonal differences are "marginal" - that is, minimal and usually "not audible", but definitely "measurable", as shown by the attached diagrams of my two HD800s!
The 7 utopias that I had longer all sounded slightly different "to me" - no better or worse - I heard 5 of them in the same "chain".
Of course, knowledge alone influences subjective perception about the production processes
I just wanted to say that after receiving my current Utopia from the 2nd repair, I was delighted that "these are audible to me" sound better - of course in the same chain.
And because this impression coincides with the experience of “BassicScience”, “I” consider a silent up date to be “possible” - silent up dates or down grades are completely normal and are not communicated, which is why nobody usually notices To explain: Down grades are rarer and are usually made through the use of cheaper components
