jlbrach
- Jun 4, 2005
my suggestion is if you are going to listen through the utopia that you use a lossless source rather than spotify.....just my 2 cents
Thanks for the suggestion, but I've done enough A/B/X testing that I find it difficult (for me) to accurately get even close to one sigma on lossless vs high bitrate lossy with a variety of gear. YMMV though.my suggestion is if you are going to listen through the utopia that you use a lossless source rather than spotify.....just my 2 cents
Man, I wish I could dislike posts here.kind of like buying a super high end 4K TV and using rabbit ears with it,good luck
Also, using a common source like spotify at least offers others the opportunity to check it out for themselves.
I suggested you to talk to your dealer or Focal.
Just curious. How does one talk directly to Focal? I've sent them email from their on-line form, and gotten no reply. All their support pages say is to contact your dealer. This is in the USA. Maybe it's different in other countries.
Also, what is the point/value to the Warranty Certificate? If a focal product is registered and I have the warranty certificate in my name, do I still need my original proof of purchase for warranty work?
Thanks.
Thanks for the detailed information. I have the HA-1 as well and it's being fed through coaxial line from a Marantz CD5004 so the volume levels may very somewhat from your setup but they should be close enough to get some idea of the conditions that may be contributing to the problem.I'm running Utopia through a HA-1 Dac/Amp combo with gain level set to high with -20dB on the dial which is fairly low on the non-linear curve. We're not talking super loud here. Windows sound is usually set to 100% and I also have a +4dB boost on bass frequencies to make the bottom of Utopia a little more to my liking. I've been running the bass boost for months (+6dB was causing mild clipping on extremely bassy tests so I backed it off to 4dB). I don't recall any clipping/rattling for months with that setting. I'll try running the gain on low with a higher volume and see if there is a difference. Its a very subtle rattle that occurs on larger bass transients and sometimes on the trailing note of mid frequencies. I first noticed it on the left channel, but it also happens on the right channel, but almost never together. I've been wondering if the source is a poor master with rare clipping, so I've been trying all sorts of different sources (DSD, FLAC, Spotify, Youtube). The effect is subtle and not happening all the time, but my ears zero in on it pretty quick because Utopia is so damn clean usually.
Test 1:
Listening to Hollies - Long Cool Woman In A Black Dress (1993 remaster) on Spotify right now with the volume turned up to -14dB and can hear faint buzz/rattle in right channel preceding either the bass guitar strum beat or that with a combination of the bass drum getting kicked. Man it's faint, but its there sometimes. Replaying the song on low gain with volume at -1.5 dB to 0 dB and can still hear a faint rattle in right channel on the same note combinations, albeit perhaps a bit more faint/infrequent. Hard to volume match the different gains.
Test 6 (I played 4 additional songs before finding another candidate):
Listening to Bush - Everything Zen on spotify volume -14.5 dB High Gain. At about 30 seconds in there is a bass guitar melody accompanying singer and I hear slight rattling again in right channel. Switching to low gain and attempting to volume match brings about the same rattle. I'm thinking then it's not to do with gain selection, but either one of two possibilities:
1) My 4dB bass boost is now clipping. Odd as I had no issues with this for months...
2) Something has come loose within the Utopia?
Out of curiosity, is your utopia using the xlr or TRS output? Wish I had a SPL meter to check myself. It's been about 15 years since my last audiologist testing for WCB (OSHA equivalent) so not sure how my hearing is doing these days. It was pretty good back then, but 15 years is a long time.Thanks for the detailed information. I have the HA-1 as well and it's being fed through coaxial line from a Marantz CD5004 so the volume levels may very somewhat from your setup but they should be close enough to get some idea of the conditions that may be contributing to the problem.
With the gain level set on high and the dial set on -20 db, my SPL meter was reading a peak of 87 db on the Falconer (power metal) CD I was using for the test. That's pretty loud and beyond what OSHA considers to be a safe level for an extended period of time. When I set the dial on -38 db, the SPL meter was reading a peak of 78 db which would be an acceptable level for the longevity of both ears and headphones alike. My test rig may not be the best. It consists of the SPL meter being stuck through a CD while being pressed against the ear pad but I trust it's accuracy more than some of the other options.
When I first tried the Utopia with the gain set on high, I noticed faintly hearing music when the level was turned all the way down. Deciding it was a sign of impedance mismatching, I than proceeded with the test using the PM-2. It was the first time I ever cranked the PM-2 up that high using the high gain setting of the HA-1. It wasn't pretty.
How MTME does it is we would get whatever warranty info you have and also recipet (if you have it). I say if you have it because we really just need some proof- bank statement, Paypal payment ect that you bought it off us. Then we get the serial number and then communication with Focal starts.Just curious. How does one talk directly to Focal? I've sent them email from their on-line form, and gotten no reply. All their support pages say is to contact your dealer. This is in the USA. Maybe it's different in other countries.
Thanks.
I compared both SE unbalanced and XLR balanced from the HA-1 using the Utopia's OEM cable for unbalanced and a Silver Dragon for the XLR output. The difference was around 10 db more balanced. With the HA-1 set on -20, it would be 75 db unbalanced and 85 db balanced.Out of curiosity, is your utopia using the xlr or TRS output? Wish I had a SPL meter to check myself. It's been about 15 years since my last audiologist testing for WCB (OSHA equivalent) so not sure how my hearing is doing these days. It was pretty good back then, but 15 years is a long time.
I used my PM2 for the high gain level testing above 80 db, it's efficacy is equal to that of the Utopia and I figured it wouldn't hurt as bad if they went out in a blaze of glory. I think the PM2 was coming close at 87 db, the bass was starting to distort so I ended the test at that point. I fond levels above 83 db to be uncomfortable but everybody's different.. The only way of knowing your actual listening level is to test at the ear cup. With the ever increasing audio and bass levels of modern recordings, it's very easy to over do it in the pursuit of happiness and end up with damaged equipment both biologically and transducer wise.
Meomap mentioned in a previous post that the rattle was present during periods of bass decay, I'm wondering if this may have something to do with the Utopia's ability to convey echo like no other headphone I've experienced. Maybe the rattle is actually the last resonant sound coming from the body of a string bass, something most of us have never heard but only the Utopia's have the ability to reproduce. Perhaps just random thoughts from a a muddled mind.
