Focal Elegia - what do you think?
May 22, 2024 at 9:44 PM Post #4,876 of 4,891
BRIGHTER PADS FOR ELEGIA?
From your experience which pads produce the brightest sound? I.e more treble without boomy bass???
The Elegia have a very relaxed treble, so there's not much that will make them sound bright other than EQ. I like the Dekoni Stellia pads, but mostly because they add a bit more mid-bass and level out the treble. No amount of pad rolling will make the Elegia bright, though.
May 23, 2024 at 9:41 PM Post #4,877 of 4,891
I can't comment on different pads because I haven't tried them. However I really enjoy the stock pads. I noticed you have the dekoni stellia pads which I've heard adds midbass. I actually enjoy the unique tonality of Elegia with stock pads. I've kind of worn mine out so seeking replacements. Have you tried them with the stock pads or only used the dekonis?
I may have missed it here but has anyone tried the zmf pads with elegia?
May 23, 2024 at 9:55 PM Post #4,878 of 4,891
I've been meaning to, because the suede ZMF pads I have on my Fostex T60rp transformed the sound of that headphone for the better and improved the comfort by an order of magnitude. The only thing stopping me is how happy I am with the Dekoni sheepskin the Elegia is wearing now.
May 24, 2024 at 3:14 PM Post #4,879 of 4,891
ELEGIA "OPEN" MOD (a warm 109Pro?)
The increased clamp force using the Chinese "Audeze type" headband caused an unwanted boominess and veiled presentation.
In my attempt to get my project phones (see above) a bit brighter without resorting to EQ, I bit the bullet and made my an opening in the centre of the cup.
I carefully drilled into the wedge shaped soft plastic. I had to be very careful not to push the bit too far, and finished off the opening with a Dremel. Followed by a good vacuuming. This mod is reversible:
  • WIN11 > FiiO K7 >Meze "silver" 4.4mm cable > Open Elegias with stock velour pads.
  • Compared to Meze 109Pro with Meze copper 4.4mm cable.
  • Test Track Easy Money by Ricky Lee Jones (Tidal MQA)
  • Hearing profile: older ears, with a dip at 6.5Khz and nothing audible above 12Khz.
Test results:
Isolation - obviously they have lost a lot of the isolation. To be expected.
Bass - a big improvement... the boomy and veiled bass is replaced by a warm bass. The 109s present a tighter more realistic tone on the close miked acoustic bass. I get an image of fingers plucking on the strings.
Winner: Meze.
Mids/Vocals: the open Elegias present a slightly warmer mid range. Ricky's voice is very enjoyable. The 109s are slightly more forward, but present a brighter, actually sibilant tone.
Winner: Elegias.
Treble: The "open" Elegias are warmer. The 109s do a great job of presenting the snare brushes and tambourine cymbals in fine detail. The 109's sibilance is still evident.
Winner: draw. It is a personal preference depending how bright you like your phones.
I feeI can pause on this project for now, as the Elegias are now pleasant to listen to.
I don't think I would have modded my expensive (I paid $1,108 CAD five years ago) Focals, but having to replace the headband opened up my curiosity. A fun project.
EDIT: I reversed this mod using a patch of adhesive vinyl. It's a shiny surface and I believe I have squeezed out a bit more brightness.
BTW, I found the Focal designed vent; it is a small rectangular opening (on the left side), covered in fabric. It vents trough a tube to the back opening.
May 31, 2024 at 2:39 AM Post #4,881 of 4,891
Hello, I plan to take an elegia with a dx260. But I would like to have opinions regarding the ZMF pads compatible with this audiophile headset because later I plan to buy a ZMF.
I was thinking about a zmf cable but which one would be best in your opinion?
Thank you for your answers.
Jun 2, 2024 at 7:49 AM Post #4,882 of 4,891
Should I...
Buy a pair of the Dekoni Custom pads OR pick up a cheap pair of the Celestee I've spied?
depands on how cheap the celestees are, i've heard (and read) that they are a significat upgrade from the elegia.
Jun 2, 2024 at 7:54 AM Post #4,883 of 4,891
Depends, they stage narrower and feel less spacious, have pretty similar detail and timbre, but better tonality. It's not a huge change. I'd say Elegia > Radiance is a straightfoward upgrade, some people may prefer Elegia/Celestee depending on EQ and preferences.
Jun 2, 2024 at 10:35 PM Post #4,885 of 4,891
thanks, i've never actually heard the celestee, as i said. i was just going off reviews i've read.
Jun 2, 2024 at 10:40 PM Post #4,886 of 4,891
I'm new to headphones, six months or so. Enjoy the sound of the experience of the Eligia, there's really nothing obviously poor sounding. After reading reviews I thought the Celestee might offer a slighly warmer/fuller sound. Some swear by the Dekoni pads and that could be a more cost effective solution.
Jun 2, 2024 at 11:38 PM Post #4,887 of 4,891
Just depends on what problem you’re trying to “solve.” For me, the Dekoni Stellia pads smooth out the treble response a bit and slightly improve the bass boominess, and they are also significantly more comfortable than the stock Elegia pads.
Jun 2, 2024 at 11:44 PM Post #4,888 of 4,891
No problem to solve as such, just a desire for a slightly warmer/fuller sound. If the Dekoni's take the Eligia a step in that direction then I'd be happy.
Jun 2, 2024 at 11:50 PM Post #4,889 of 4,891
Huh. For me, the Elegia is already an uber-warm and full tuning out of the box (many people don’t like it precisely because it leans so heavily into warmth and richness). Haven’t heard the Celestee myself, but on paper and in others’ takes, it looks like the Celestee moves in the opposite direction from the Elegia toward more clarity and balance.
Jun 2, 2024 at 11:57 PM Post #4,890 of 4,891
Huh indeed!
