Chiaroscur0
Oh I mean the muted sound it was really quiet after I applied the eq. When I first listened to it, it sounded a bit less detailed not exactly hushed but lacking of some sort. I'm still trying to figure it out.
Surprised it wasn't 100%, though sound is greatly influenced by the shape of our ears so the same setting will actually sound different to different people (to varying extents.)
oratory1990's setting indicates three bands to adjust to taste for bass, mid, and treble respectively; you may try playing around with those to see if you get to 100%.
And in Harman's testing, 1 out of 3 people liked something different than the Harman target response.
These are pretty dramatic EQ values in my book, will certainly change the HP in the direction of Harman target, but will devoid them from their original character in the process. IMO, if you're after a HP that does Harman well, get one that is close to begin with, and tweak it from there.
While I have no reason to disrespect Oratory's experience and far superior knowledge to mine, I can't really wrap my head around the concept of EQ-ing all headphones to the same target, sometimes going against the grain and losing intrinsic strengths they might have in the process?
I would be pairing this with a Gumby into either a Jotunheim or Liquid Platinum. Would these have good synergy together?
It might be the good ole burn in effect( getting used to how it sounds) not actual burn in.
It is true that applying these settings will fundamentally alter the Elegia's character—but if you're EQing the Elegia, altering their character is what you're after in the first place. If you're fine with their sound signature, why EQ it?
If anyone is looking for a mid priced dac/amp and don't need to much power but truly wants pure focus on SQ that seriously punches above its price. This thing is it!!!!!! :O make sure it's the Version 2 though .
I don't have experience with the Stellia or Clear, but from everything I have read in this sub, the Stellia is a direct upgrade to the Elegia, and the Clear is also a better headphone then the Elegia as well. I have not read how it compares to the 6xx.Would it make any sense in spending $250 on Sennheiser 6xx on Massdrop or $450 on Elegia when one already owns Clear and Stellia and loves the same? Need your advice for my purchase decision.
Need them? Probably not, the improvements are small to my ears in terms of sound signature. Definitely an improvement though. The Sheepskin pads are great. However, if you have an issue with the seal of the stock pads, the added thickness of the Dekoni's may help with that. I did not have a problem with the seal of the stock pads, and I wear glasses, so ymmv. I'm wearing my Elegia's now with the Dekoni's, they are super comfortable, though they do make me sweat more than the velour stock pads.None, mine sound great. I’m looking closely at the comments about the Dekoni Sheepskin pads. I’m trying to decide if my Elegia’s need them or not. The Silver Dragon cable I have on them cleans things up considerably. The bass is so good that the extra bass the Dekoni sheepskin pads adds might make them boomy.
I was doing a run from my s9+ using the vlc player and it sounds pretty good if not great to me. I think windows groove is doing something stupid. I should probably change from the player but its simple and usually works fine. I did double check to ensure theres no eq applied.I think that's more common than actual physical burn-in. The giveaway is when you buy used headphones and they still keep getting better and "opening up" for the first few weeks of listening. Always happens for me.
