cel4145
What amps are you guys using and or recommending???
Asgard 3 4490 myself might move to pure class A or one of the super low distortion units Atom or THX possibly
Anyone using Xduoo xd05??
JDS Labs Atom measures as accurate as much more expensive DAC/amp setups. And it will easily drive the Elegia on low gain.
I had the Xduoo XD05. It's more transportable then portable, because it's a brick. So I would not buy it with the idea that you might use it for some portable use. I did that, and then ended up getting rid of it.
