Hi, whats the name of focal elear cable adapter or full cable? The end its too thick, I cant plug it into my phone
Do you have a photo.Hi, whats the name of focal elear cable adapter or full cable? The end its too thick, I cant plug it into my phone
Hi all, long-time lurker first-time posterfor my taste, Elear Bass is not tight enough for metal music...
any possible to Demo?
IMO, Clear / Elex will be suit for ur type of music..
Regarding the Elear the bass is tight enough if you use Reference 4 like another member posted. Without Ref 4 I find them a little mushy at the lower end. With the calibration they sound a lot like the Clear, which I also own. I can't really tell which one I prefer between them and that, even though I mostly listen to fusion on both. It mostly depends on the instruments used by the musicians, bass like Marcus Miller is better with Elear but for keyboards and sax I have a slight preference for the Clear. What I don't like about the Clear is its color No really, the Elear looks like it means business while the Clear needs to take a shower quite often, those pads are stain magnets.
Hi, does elear's have narrow soundstage?
Not necessarily. Slightly more spacious than the hd660s... now that's more narrow. Though I'm pretty sure these aren't in the hd800s league.
I thought the open back plus juicy bass has always been an attractive duo.
When I auditioned a selection of headphones, I found the the HD800S were a bit too bright for me. Plus every time I took them off, my fingers went into the slots and I thought that I would end up damaging them. In the end I chose the Focal Elear out of the ones that I auditioned.
I too, like the "juicy bass", particularly for Jazz music for the Drums and the Double Bass.
Two months with these headphones...Always impactul, Dynamic , realistic and smooth .
Very serious recommandation for intimate listening lovers.
Amazing Q/P ratio.
I still think it sounds more natural and true to life than it’s pricier big brother, but I guess that is a matter of taste. My friend slightly prefers his Clear
I totally agree, the Focal's are just luxury in sound and in design!Two months with these headphones...Always impactul, Dynamic , realistic and smooth .
Amazing Q/P ratio.
