abirdie4me
- Mar 6, 2017
The difference in sound won't be because of the Cable but rather design of the amp. You'll have the best performance out of the Balanced Output on a Balanced Amp. So if you amp has both connections, chances are it was designed for balanced and will have the cleanest output and better sound on that side. I'd recommend spending a week with the Balanced side, then switch back to the Single End.
Thanks, I guess I need to find a good balanced cable for my Elears to see if my Jotunheim sound better through its balanced outputs.
