catscratch
- Sep 29, 2004
Suspension headbands are really good. However they do look goofy, and depending on the design, the elastics that hold the headband in place will get weak over time, causing the headband to flap around when you're just picking up the headphones and they aren't on your head. That's a bit unseemly. So from the standpoint of style, Focal's design is solid.
I like the Sennheiser design, tbh. No flappy headbands, and no pressure on top of the headband. Though it's also a tad less comfortable than suspension headbands.
The biggest fail in terms of headbands is, weirdly, the Stax SR-007. It's a self-adjusting headband in that the tension of the elastics counteracts the weight of the headphones to hold them exactly in place. The problem is, the elastics are too tense, and the headphones end up sitting too high, in a headphone where fit is absolutely critical to the sound. Over time they loosen up and the fit becomes normal, but damn. I see why they switched away from this design for the SR-009, and I wish they'd update the SR-007 with the SR-009/LX00 headband too.
However, none of these headphones are uncomfortable, truly.
Buy the original SR-003. Suffer. Understand.
The SR-001 Mk2 / original SR-003 sounds really good. One of the best things for vocals, ever. But damn, that comfort... The Spanish Inquisition would be proud. I had multiple pairs and got rid of them all. When your ears literally swell shut after 30 minutes you know you have a problem. Stax redesigned the eartips for the SR-001 Mk2, and I've seen photos of a prototype that redesigned the eartips again, so we'll see. At least they're trying.
