Focal Clear headphones
Jul 26, 2022 at 7:35 AM Post #10,817 of 12,651
so the focal clears arrived today. Also bought an HP Elitebook 17in to use as a media center/TV (watching something during my lunch break WFH). I will be using my DIY tubed amp for now while waiting delivery for a audio-gd dac/amp combo.
The ones I demoed in the store are the grey/dirty white version. but found these Focals at a discount (around $75USD cheaper than the greys) and I love the color scheme!
Aug 8, 2022 at 9:40 AM Post #10,819 of 12,651
I think they are actually great for the money. Quality seems good. No weird smell, no residue glue. They are correct size and nice feeling and sufficiently stuffed (my earlobes do not touch the inner grill unlike massdrop 2020 focal elex pads). Should have bought the leather ones though.
Aug 8, 2022 at 9:51 AM Post #10,820 of 12,651
that looks nice. are they the same depth as the original ones?
Aug 8, 2022 at 1:08 PM Post #10,821 of 12,651
They seem to be slightly shallower, but i guess they don't crumple as much cause my earlobes don't touch the insides.
On the right are the famously criticized focal elex pads from Massdrop which I cannot use, since my earlobes touch the inner grill of the headphones.
On the left is my original pad that has been washed several times and is super messed up and stretched out.
Aug 8, 2022 at 2:05 PM Post #10,822 of 12,651
It does not use fabric ring as OEM pads, the only aftermarket pads that have them are Dekoni Stellia LTD.
Aug 9, 2022 at 8:08 AM Post #10,827 of 12,651
Just be aware that the pads have a big influence on how the Clears sound.
I have been testing the Clears with the original pads, Dekoni Velour and Ltd Stellia, and with the Focal Utopia pads.
The original Clear pads and the Utopia pads have a similar refined and open character with the Utopia pads sounding a little more natural, open and refined.
The 2 Dekoni pads sound somewhat closed in, more bassy and punchy in comparison, the Ltd Stellia pads more so than the Velour.
Frankly, the combination of high price and short lifetime of the original pads is a bit of a bummer.
The Utopia pads may be the better long term solution despite the high price as they sound even cleaner and clearer and should last much longer.
Aug 11, 2022 at 1:00 AM Post #10,829 of 12,651
Is this the wiring when using a balanced 4-pin XLR? this a male XLR that's facing towards you.
(I don't have the Clears but the Clear Pros which didn't come with the balanced cable)
Aug 11, 2022 at 3:32 AM Post #10,830 of 12,651
That's correct. Usually the connectors have the pin's soldering pots numbered inside, so it's pretty straight forward.
Check this guides for more details regarding DIY cables. robrobinette.com/BalancedCable.htm
