Focal Clear headphones
May 15, 2022 at 8:09 AM Post #10,606 of 12,550
Focal’s warranty registration page and authorized dealer page. That’s why I trusted to buy there in the first place.
Focal’s warranty registration page and authorized dealer page. That’s why I trusted to buy there in the first place.44DD2315-042C-49D6-B706-DBA61FE96D3B.png5C573194-85B1-4D4B-9900-7EA9D4D2D9D7.png
I didn't see them, cool. Return should be smooth, hopefully.
May 15, 2022 at 8:22 AM Post #10,607 of 12,550
They responded last night apologizing for the mixup of the product but stood firm that they weren’t used or a display unit. Unfortunately, that is patently false, the headphones weren’t in the focal brown box with the anti tamper label nor were the cable connections correctly wrapped in clear plastic. Also the cables were in disarray. 100% used. They claim they got them from the vendor just like that.
They said they would be sending a return label immediately, it’s been 14 hours since response, no label.
May 18, 2022 at 5:05 AM Post #10,608 of 12,550
Focal Clear on Cavalli Liquid Carbon v1. Still my favourite solid-state amp for the Clears. When not on tubes, this is my go to.
Jun 5, 2022 at 10:37 AM Post #10,609 of 12,550
It happened! My 1000€ headphones' left driver tapped out. I happened a few weeks ago but I've been in denial until now.
I know it has happened to a lot of you before. My warranty finished 6 months ago. What should I do?? Is there a chance I can fix it by myself if I open it up?
Jun 5, 2022 at 11:42 AM Post #10,610 of 12,550
It may be able to be fixed if you know how to solder.
Jun 5, 2022 at 12:21 PM Post #10,611 of 12,550
Focal Clear OG is at $890 at headphones.com
Jun 5, 2022 at 1:35 PM Post #10,612 of 12,550
Jun 5, 2022 at 1:43 PM Post #10,613 of 12,550
Have you done it before?
Yes I have.
If the voice coil wire popped it will be more difficult, you will have to use a similar size cca strand to solder on but if its just the solder joint going dead as they're known to, its very easy.
Jun 5, 2022 at 3:57 PM Post #10,614 of 12,550
At some point Focal extended the warranty on the Clears. You should check with Focal or with the authorized dealer (I hope) where you bought them.
Jun 5, 2022 at 4:59 PM Post #10,615 of 12,550
To be honest, if I were to get another focal headphone, I would preemptively resolder those joints so that it doesn't fail in the future.
Whatever the solder they're using, its garbage because there was a significant sound quality improvement from upgrading the solder on that joint to mundorf supreme.
Initially I only did the left side but the channel imbalance was too much to ignore, so I resolderred the right side as well.
Jun 8, 2022 at 2:58 PM Post #10,616 of 12,550
If there is a planar equivalent/brother/upgrade would be fabulous to the Clear OG? Which one would that be?
I'm contemplating either trading in my OGs for a pair of Utopias - would that justify 3k?
Or complement my setup with "matching" planars...
Electronic music... therefore I'm not even sure if there are "better" planars than 1266TCs! (comfort and price aside which are actually exclusion criteria)
Thanks for Tipps!
Jun 8, 2022 at 4:45 PM Post #10,617 of 12,550
I posted this in the MG topic but it might be something worth considering for the OG's as well: What you see is a defean/geekria replacement pad mounted using a 3d printed mounting ring. Pads are widely available at amazon https://www.amazon.com/M30-M40-M40X-M50-M50X/dp/B07T7W2Q15/138-0848034-4079131. This is the closest I got to the stock pads. None of the Dekoni pads came close imo and at $15 for the pads (and $15 for a pair of rings) these can be a cheap replacement / experiment for some :)
Jun 8, 2022 at 8:48 PM Post #10,618 of 12,550
Got the Clear OG on sale and as a backup as certain other cans are going to the shop (again..obviously) - expectation has been subverted so far. How did I skip this one after hearing the other Focals :thinking:
Jun 8, 2022 at 8:50 PM Post #10,619 of 12,550
Which other cans?
Jun 8, 2022 at 8:59 PM Post #10,620 of 12,550
Which other cans?
Utopia, Stellia and Celestee. All at meet/show condition and none sounded all that pleasant to me. I am not a huge fan of Focal speakers either.
