Luckyleo
Thanks! Sounds great with my SP2000. Jot2 on the way with a Bifrost Dac.The Clear on an OTL has impedance matching issues. Go hybrid, or Solid state to get the best out of them.
I've found that the Clears shine on the OTL amp when we have well recorded Americana, Classical, Jazz, and most Rock. The horrible sound I was experiencing came while listening to live Grateful Dead recordings that were not the best recorded to begin with, with heavy drums and bass portions. Live and learnPer the discussion above. I see it now. Thanks again for your help
looks great! how are you liking the Dekoni fenestrated pads??Focal Clear with accessories: headband cover (various types are available on eBay), Dekoni fenestrated earpads, Arctic Cables Palladium Series. Result?
For me, the Dekoni are . I chose the fenestrated ones to emulate the design of the stock pads. I felt that the stock pads were too squishy and wanted something a little firmer. I had my doubts about the longevity and later appearance of the stock pads. With the Dekoni, a light wipe down with a barely damp cloth with soap is all the maintenance needed. As for sound, I have not sensed any real shift in frequency response or balance. The soundstage, which I feel is very good, is a bit wider: the added physical thickness of the Dekoni versus that of the stock pad pushes the Clear speakers further from my ears. All the above, for me, reinforces the notion that the replacement price of the Clear stock pads is absurd. As in all things audio, your “earage” may vary...looks great! how are you liking the Dekoni fenestrated pads??
For 5 feet (1.5 metres), with the XLR amp termination, yes, the PS is shown as $1634. One offsetting factor, to my mind, is that the Clear terminations work for the Kennerton Gjallarhorn.I did a search for that cable. Is it really $1600 ? Unless I'm looking at the wrong thing lol.
FostexThat last thought could get me on the headphone cable industry standard soapbox....Sennheiser & Foster connectors look alike...interchangeable?. Why does Utopia have LEMO? Why does Audio-Technical have A2DC? Beyerdynamic has their own extended 3.5mm connector...and so on...
That's weird, OTL amps have high impedance correct?I've found that the Clears shine on the OTL amp when we have well recorded Americana, Classical, Jazz, and most Rock. The horrible sound I was experiencing came while listening to live Grateful Dead recordings that were not the best recorded to begin with, with heavy drums and bass portions. Live and learn
I agree with @kyotousa. A typical output impedance reading for an OTL headphone amp would be 120 ohms. The static impedance for the Clear is 55 ohms. A very rough rule-of-thumb for non-aberrant headphone frequency response has been: headphone ohm => 2x-3x headphone amp ohm. I would not expect a favourable pairing between OTL and Clear. My two favourite h/p/a for driving the Clear are the Liquid Platinum and the Violectric V280. The output impedance for these, respectively, are 0.140 ohms and 0.165 ohms. These h/p/a are favourites for Clear for reasons well beyond compatibility.That's weird, OTL amps have high impedance correct?
0.3 is “electrically” good in that pairing 99.9+ percent of headphones with the Mjolnir 2 will not result in a significant measured deviation from flat frequency response. FFR is only one part, though, of overall sound quality.I suppose 0.3 on the Mjolnir 2 on low gain is good?
Speaking of Mjolnir 2 . I sent mine away to Keith for modding lol. Just like I played guinea pig with the LP.
