Focal Clear headphones
Mar 21, 2018 at 3:29 AM Post #3,151 of 12,550
You’ll lose bass response if you use either of those 2 types of pads on the Utopia
I tried elear pads on clear. They give the clear a bass boast. I much prefer clear with stock pads.
Thanks. So maybe I would lose bass by using utopia pads, but what would I gain? The last bit of refinement? Maybe a baby Utopia? :wink:
Mar 21, 2018 at 4:52 PM Post #3,152 of 12,550
I am in the unfortunate position of having left my Focal headphone case on a plane (and on my second outing with the Clears). Some lucky passenger on the DC to Norfolk flight is now the proud owner of my case (and my name and contact info were included...)
My local dealer reports a mid April delivery of Focal cases. Any dealers on this thread have the headphone case in stock?
My thanks to @MTMECraig and Mark Mawhinney, both at Music To My Ear. Craig responded promptly and I bought the case for $125. Painful, yes, but $25 less than list price. I received the case within 24 hours so all is well for now. I'll be more careful on my next trip...
Mar 21, 2018 at 5:41 PM Post #3,153 of 12,550
I’ll send them a case so you don’t have to wait if you like.
The Source AV TSAVJason Stay updated on The Source AV at their sponsor profile on Head-Fi.
https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
Mar 21, 2018 at 5:43 PM Post #3,154 of 12,550
Hahaha I’d like to say yes but I can’t. It’s just not a good match together really
Mar 21, 2018 at 6:40 PM Post #3,156 of 12,550
Thanks, but no need. I received the used headphone case from Music to My Ear, so all is well.
Happy to hear that. Music to My Ear are good people and as such I had no issue helping them get you a case. :) cheers
Mar 21, 2018 at 8:00 PM Post #3,157 of 12,550
Just out of curiosity, is there any reason Clear needs to come with a balanced cable? Why don’t they provide just one cable and multiple adapters for different connections like balanced-1/4 and 1/4-8? Do adapters deteriorate sound quality? If anyone knows about this matter, teach me plz.
Mar 21, 2018 at 8:11 PM Post #3,158 of 12,550
In fact yes, adaptors aren’t the best option. You’d want to think of it as a solution or convenience. It’s always best to have a direct connection as in “end - end” with no breaks between. As a note: This is the premise of WireWorld, to sound like there is no wires, just a direct connection. Hope that helps :)
Mar 21, 2018 at 8:35 PM Post #3,159 of 12,550
It sounds like when bluetooth, amp, and dac technolgies reach perfection, all cables are destined to be eliminated ultimately (might be possible with in a century.)
Mar 21, 2018 at 8:46 PM Post #3,160 of 12,550
Yeah I know. Eventually my wife and son will know exactly where I am and what I’m doing at any time no matter where I hide (damn technology) :) Cheers
Mar 21, 2018 at 11:22 PM Post #3,161 of 12,550
You can't go SE to balanced, only balanced to SE.
Mar 22, 2018 at 12:22 AM Post #3,162 of 12,550
As already mentioned you can't go single end to balance, only balance to single end. The problem with using a balance connector as the base plug to couple with converters right now is that the most popular desktop connector is the XLR - which if you own the Clear can see - is big and heavy, so adding an adaptor to change that into different size further increases the weight of the entire cable which makes it unpractical. The other popular balance connector is the 2.5mm which is thin and fragile which won't stand up to much physical usage of lots of plugging/unplugging, also it is mainly for DAPs and isn't found much on desktop devices which means you will be doing a lot of plugging/unplugging which guarantees it is going to break. The ideal happy medium should be the new 4.4mm Pentaconn but is still too new to have gain much footage in audiophile equipment.
Mar 22, 2018 at 2:04 AM Post #3,163 of 12,550
Only once they make them in a way that harvests power from the air and thus last forever without needing a recharge, like wires.
You can totally go single ended to balanced. You just bridge the negative connectors to ground. It's not true, differential balanced, but it's connecting to the headphones in the same way that the single ended connector is.
Mar 22, 2018 at 4:46 AM Post #3,164 of 12,550
This creates a short circuit between the negative connectors on the balance circuit, which sufficient to say is a bad idea.
