Soundizer
- Dec 29, 2015
That is exactly my point. I just called NAIM in UK and reported this issue. They are feeding back to Focal Headquarters.Have anyone problems to connect the Bathys in aptX HD? I have tried with my A&K SE200 and Fiio M11 plus and didn't work. It supposed to work because aptX adaptive is backward compatible with aptxHD (https://www.aptx.com/aptx-adaptive at the end of the page)
I discovered a major negative point on the Bluetooth implementation on Bathys.
As Bathys uses AptX Adaptive it is supposed to be backwards compatible with AptX HD (because AptX Adaptive specifications on QUALCOMM website show’s compatibility with AptX HD). This is important if you have a source device which can transmit AptX HD, but not the newer AptX Adaptive.
I have such a device - Nvidia Shield TV PRO. Which is the main reason I purchased Bathys so i can listen to Movies in wireless. Unfortunately Bathys falls to 16bit Apt X instead of 24bit Apt X HD. i know this doesn’t sound nearly as good. The reason is my previously owned Sennheiser Momentum 4 which is also Apt X Adaptive when connected to Nvidia Shield would receive Apt X HD.
Something gone wrong in this implementation.
