Update took me around 10 minutes. Will have a closer look tomorrow. Done for the day today,
Focal Bathys Hi-Fi Bluetooth & ANC Headphones: Early Impressions
- Thread starter jude
- Tags
- focal focal bathys
Since this post and my last one mine has progressed 8%.
I did do everything it said not to though, locked my phone, suspended the app, and even turned off the headphone just to test what would happen and it just prompts you to reconnect, no disaster.
Campus007
What's your experience with the update? Mine is going at 1% per minute. The phone is connected via wireless at 500 mbs so It's not a bandwidth issue.
The app also states that it needs you to keep the device unlocked and the app can't stay in the background? That seems quite hard to do for an update that is going to take between 60 and 90 minutes.
Mine installed pretty quick (about 5 minutes). I had to clear the data in my Focal Android app settings because the dynamic EQ option wasn't showing up after the update. It showed up when I cleared all data but I've lost my custom EQ's (no big deal).
I've tried it and like it. I assume that the EQ will adjust based on the volume level?! Hence the use of the word "dynamic".
Apart from that, the Sidetone feature clearly puts your headphones in a reduced transparent mode so that you can hear yourself talk and some of the outside world. It's a nice feature to have.
garethr
- Jun 19, 2016
How do you even access the sidetone feature? On iOS it’s nowhere to be found as far as I can tell.Mine installed pretty quick (about 5 minutes). I had to clear the data in my Focal Android app settings because the dynamic EQ option wasn't showing up after the update. It showed up when I cleared all data but I've lost my custom EQ's (no big deal).
Same place where you would choose the digital assistant. Top right of the screen there is a wheel cog icon on Android and there are app settings that you can change there.How do you even access the sidetone feature? On iOS it’s nowhere to be found as far as I can tell.
im go to new bathys firmware tooSame place where you would choose the digital assistant. Top right of the screen there is a wheel cog icon on Android and there are app settings that you can change there.
garethr
- Jun 19, 2016
Ok. Definitely missing from the iOS app then!Same place where you would choose the digital assistant. Top right of the screen there is a wheel cog icon on Android and there are app settings that you can change there.
I need to say I love this update, Dynamic EQ was exactly what I needed to be honest. It’s a great tuning for daily commute!
I just need to check if in DAC mode logo is still on (don’t like that at all)
Bathys sound stellar now!
Best!
Kuba
Best!
Kuba
noplsestar
They also fixed the light of the logo in DAC mode. YesssssI need to say I love this update, Dynamic EQ was exactly what I needed to be honest. It’s a great tuning for daily commute!
Best!
Kuba
Is there any way to find the releasenotes for this FW update? I can’t seem to find them…
Ansch
Updated. The Dynamic EQ is definitely better than the original set of useless EQs, however, I still prefer my custom EQ which can bring out a bit more sound stage than dynamic.
I believe the release notes are in the Focal/Naim app.Is there any way to find the releasenotes for this FW update? I can’t seem to find them…
for stellar far not… not compare to ananda bt sound different league,also stellars is celestee radiance stellia…after compared vathys to those im see how foggy sounds bathys…I need to say I love this update, Dynamic EQ was exactly what I needed to be honest. It’s a great tuning for daily commute!
Best!
Kuba
Total: 7 (members: 1, guests: 6)
