- Oct 6, 2013
I found the best way to make the faceplate turn green is to expose it to sunlight for a couple minutes. The information by qdc says it needs UV light which the sun provides plenty, not so much with incandescent.
I agree, the bass switch turned on is my preferred setting as well. The graph I saw showed only a 2dB increase unlike the VX which was several dB more. Too much for me for most of my music.
I’m using my Odin cable with my V14, and I had no issues with its .78mm pins fitting. I now use the Mason FS cable with my Odin switching back and forth. Also, it was reported in the qdc thread the V14 does not invert polarity as older models did.
I have in front of me VX and V14 with their corresponding cables that interchange perfectly, both in terms of the fit and the sound without any phasing or other effects when using VX or V14 cables with V14. And my other standard 0.78mm 2pin cables don't fit V14; tried EA, PWA, Eletech, PS, and they don't go in easily unless I force it. I just tried stock PWA 1960 2wire from Odin and it doesn't fit V14, unless I apply the force to push it in. But if you do that and got it to work, maybe you stretched sockets a bit. I mean, we are talking about a very small change from 0.75mm to 0.78mm, and with +/- tolerance and variation between cable connectors and sockets some might fit better than others. But I honestly wouldn't expect qdc to change the socket without mentioning it officially and considering all of their other IEMs follow the "old" standard.
But, nevertheless, let me double check with Andrew so he can ask qdc directly. Let's verify it with manufacturer.
