zepmaj
- Feb 11, 2017
Hi everyone. Is shenzhenaudio.com any good? They have discount on flc8s, just $280.
I bought flc8s and it03 from their store. Their communication is good. They also ship through fedex or dhl, if you purchase more than 200$ (I think).Hi everyone. Is shenzhenaudio.com any good? They have discount on flc8s, just $280.
I was thinking to buy it03, but now flc8s at this price, im a little confused, also considering to expand budget for oriolus forsteni. Any recomendations? I will upgrade from vsonic gr07 be.I bought flc8s and it03 from their store. Their communication is good. They also ship through fedex or dhl, if you purchase more than 200$ (I think).
I don't have oriolus iems. So others can comment on that. But for the price I think FLC8s is no brainer.I was thinking to buy it03, but now flc8s at this price, im a little confused, also considering to expand budget for oriolus forsteni. Any recomendations? I will upgrade from vsonic gr07 be.
Haven't hear the others you mentioned, but I upgraded from the GR07 bass also. I think if you're a big fan of the VSONICs you'll love the FLC8S. At $280 I would be surprised if you regretted snagging them.
at 280 the flc 8s are a must try. it you want to go cheap, lz a4 is also only very, very slightly worse than the flc 8s, being larger, heavier, and having a slightly less wide soundstage than the flc 8s.
Hi guys,
Haven't posted on Head-Fi for a long time. My Gr07 mk II's got ran over and destroyed by a car a while back. Been using the Monster Miles Davis headphones for a while, but they just don't cut it. Especially after using the Gr07's for so long. Today I decided to take the plunge and ordered the FLC8S! Can't wait for them to arrive.
I really would like to have a mic on my headphone so I can use it for talking on the phone as well. And I was wondering if anyone knows of a good after market cable with microphone that fits the FLC8S connectors? The problem is not only are the connectors the 2 pin style, but they are also a bit smaller at 0.74 mm. Many cables out there I see are either 0.75 mm or 0.78. I would rather not have to stretch out the connector by jamming a 0.75 mm connector in it. Does anyone know of a well fitting 0.74 mm 2 pin cable with mic that would work?
On a side note, I recently listened to the Klipsch X20i IEM's and found they were quite good. Does anyone good experience listening to both the X20i and the FLC8S and can give me an idea of how they compare or which is better? And how about the Dunu DK-3001?
Also worried I'll eventually catch the bug again and look for some end game IEM after this like the upcoming FLC Celeste?
Can't wait to get the headphones! Thanks for the help!
^ Have you heard the new DUNU DK-3001? They're not bright at all and have a slightly better sound than the FLC8S. Although they do have a weird design and offer a bad fit for most, so you were right about DUNU's being a let down in terms of ergonomics.
