FLC Technology FLC8 and FLC8s Impressions Thread
Jul 22, 2016 at 4:21 PM Post #4,518 of 7,931
Jul 22, 2016 at 7:47 PM Post #4,520 of 7,931
so uhmm.. my manual is in chinese? have i been scammed? if not, can i get an english copy pleassee?
Who did you purchase them from? I don't know that you can tell that you've been "scammed" based on the language of the manual, as the IEM is Chinese in origin, and is sold in many markets. There really isn't much to the manual other than a chart indicating the sound signature of each filter and nozzle, which is available on-line and in many on line reviews. Does the packaging of your item match that shown and described in reviews? I'm not aware of any fakes on the market, but I suppose it is possible.
Jul 22, 2016 at 8:08 PM Post #4,521 of 7,931
from here
http://www.ebay.ca/itm/172017779436
it seems authentic to me but the storage circle thingy has a very slight indent where it says FLC technology.
is it supposed to be like that?
and could u point me to the english manual?
Jul 22, 2016 at 10:58 PM Post #4,522 of 7,931
Jul 22, 2016 at 11:13 PM Post #4,524 of 7,931
but i said please
The cable looks like flc8s, there is no fake flc8s don't worry. As long as it sounds good, it should be authentic.
Jul 22, 2016 at 11:30 PM Post #4,525 of 7,931
who knows man haha there are so many OEM stuffs these days.
on a sidenote, lets wait for the celeste!
Jul 23, 2016 at 8:41 AM Post #4,526 of 7,931
but i said please :frowning2:
This review contains a guide to how the filters affect the sound. It's not the actual manual, but it's the most important info the manual contains. The info on changing the filters isn't that helpful, as she tweezers don't work all that well. Best to just use your fingers.
http://theaudioexpert.blogspot.com/2016/03/FLC8s.html
Jul 23, 2016 at 8:52 AM Post #4,527 of 7,931
Once you get the hang of it it's very easy. The ones that have a little screw shape and is plastic are subbass filters (red being highest, white being lowest amount). Now the little rubber sticks that go on the surface of the IEMs are bass filters (black being highest, white being lowest). Finally the big metal screw looking thing screw onto the bore. The blue = mids, less highs. The gold = mids, highs. The black = mids, more highs. The green = mids, extreme highs. I personally think gold is the most balanced, black gives some sibilance. Just pick the mids,highs filter that you like and adjust the bass and subbass depending on your preference and tips (fit), and source of course. Believe it or not, tips do actually change the sound. Even switching the sizes of stock tips alter some parts of spectrum to be attenuated or diminished.
but i said please
Jul 23, 2016 at 10:42 AM Post #4,528 of 7,931
Yep, that would be my review and can also be found here on Head-Fi: http://www.head-fi.org/products/flc-technology-flc-8s/reviews/15623
Jul 24, 2016 at 2:25 AM Post #4,530 of 7,931
Anyone know where i can buy a good 2.5mm trrs to 3.5mm adapter ? I need it for my flc 8s with 2.5mm balance cable. I found one at http://www.norneaudio.com/litzheim/norne-audio-cable-cables-hypershort-ultrashort-eidolic-balanced-trrs-4-pole-female-3-5mm-rhodium-astell-and-kern-a-k-adapter-direct-soldered-conversion, but its quite expensive.
