So I've found a defect in my FLC8S that is clearly responsible for my ULF filters popping out of the left monitor. I've lost two today alone, one of which I was unable to find and is now gone for good. If you look closely at the ports next to the nozzles you will see that they have rubber gaskets inside of their rims, to seal the air pressure and prevent the filters from coming loose. My left monitor has no visible gasket because it appears to have popped itself inside of the IEM. The rubber material inside of the monitor's body prevents the filter from entering fully, and there is no seal around it; ergo, the filter juts out from the monitor. I can press it flush with my finger but the moment I let go it immediately pops partially back out. There is no way I can even try to fix this without risking damage to the IEMs.
I have taken multiple high-definition photographs of the ports both individually and side by side, as well as how they look with their respective filters in place; however, I am currently on vacation and all I have are my cellphone and tablet. I'm not sure how I'll upload the pictures at the moment. I'll try to figure that out ASAP, for proof.
I don't know how this happened. I'm not a wealthy man and I baby my IEMs. These were a present for graduating with my Master's degree. For me, this is a huge loss--especially since I'm two hundred miles from home and now I can't even fall asleep listening to my music. Tonight my soundtrack is sadness. If anyone reading this works for FLC or knows someone who does, please help me! My wife purchased these from Lend Me UR Ears, fulfilled via Amazon. They're the first defective IEMs I've ever owned and I loved them dearly while they worked. I need someone to help me out and make this right. It would mean a hell of a lot to me.
