Nov 9, 2012 at 11:15 AM Thread Starter Post #1 of 49
nikkojames15
I have a SoundMAGIC PL-30 IEM, and I was wondering if there was a full-size headphone within $100 or less that has the same mid-range detail and flat response of the PL-30. It doesn't matter if it's open or closed, although a portability could be useful. Bass should be just right, not boomy, but with more quantity than the PL-30. Thanks in advance!
EDIT: I upped my budget to $150, seeing as it's quite hard to find what I need at that price point. :D
UPDATE: I'm currently considering the Sennheiser HD280 Pro, HD518, KRK KNS-6400 and Brainwavz HM5. Will update as I audition each headphone. :D
Nov 9, 2012 at 11:30 AM Post #4 of 49
You may want to look at the Sony MDR-ZX700:
http://www.headphone.com/headphones/sony-mdr-zx700.php
The same goes for the Sony MDR-V6:
http://www.headphone.com/headphones/sony-mdr-v6.php
The Shure SRH440 is also very mid-centric.
http://www.headphone.com/headphones/shure-srh440.php
Nov 9, 2012 at 1:30 PM Post #5 of 49
Heya,
AKG K240 for $80
Very best,
Nov 9, 2012 at 1:50 PM Post #7 of 49
I think the only headphone i've seen that measures flat for under $100 is the KRK KNS-6400.
I'll leave it up to you to decide if it really sounds that way
Sorry, but the V6 sounds rather V-shaped to me. Sounds like it has some mid-bass hump, a dip in the lower mids somewhere and then extra treble.
I like the K240 Studio suggestion, but it does have a slight mid-bass hump. I actually think it's probably more balanced sounding than the V6.
There's also the M30..
Nov 9, 2012 at 2:01 PM Post #8 of 49
Seconded.
Its an impressive studio headphone for under $100.
Nov 9, 2012 at 3:39 PM Post #9 of 49
Shure SRH440 are your friend, stick some SRH840 pads on for extra comfort
i agree on this one, very detailed set of cans too
though im not don't know about the srh840 pads
Nov 9, 2012 at 3:47 PM Post #10 of 49
The Sony V-6 is your classic. Can't go wrong there. It should be on your short list. Haven't heard the others mentioned here.
Nov 9, 2012 at 6:42 PM Post #11 of 49
The V6 sounds very good for the price (I paid $70) with honest mids and treble but they are not flat down low at all, as the OP requested. The sub bass is very enhanced and can be "boomy" on tracks that reach down low enough.
Nov 9, 2012 at 10:12 PM Post #13 of 49
Thanks for all the suggestions guys! Currently I'm looking at the Shure and the MDR-V6.. Not sure if I could find a local dealer of the KRK though. I hate buying online..
Nov 9, 2012 at 10:15 PM Post #14 of 49
Are you against using EQ?
Not really, I just like the flat sound signature, and I currently suck at parametric EQing..
Nov 9, 2012 at 11:01 PM Post #15 of 49
I asked because it will be near impossible get very neutral sound for such low price, but if you get something that's very balanced to begin with, you can always fine-tweak it using EQ.
