Jonathan Dunham
- Aug 23, 2016
My biggest sound concern is and always has been immersion. I'm looking for a sound that makes me forget I'm wearing IEMs, a powerful musical sound with a soundstage that I cannot sense the end of. A wide, deep, spacious, even cavernous sound. An organic, smooth, non-analytical mid-range (non-abrasive) with complimentary treble.
If anyone had heard the Acoustune HS1551, that kind of spacious only with higher resolution and even wider, enveloping stage.
Does the Flare Pro 2 HD achieve this kind of sound? Can anyone articulate in detail the stage dimensions, imaging, layering, separation, 3D-ness, transparency?
My comments FWIW.
Firstly, a slight caveat in that I have the Pro Gold not the 2 HD and of your list only ever heard the EX1000 in comparison. But the Gold and 2 HD really are minimally different, have the same brass enclosures with similar if the not the same shape of driver exit at the front.
Overall I do wonder whether you’re looking for something that just doesn’t exist in an IEM. And that is the soundstage and imaging. Full headphones are able to do a much better job (my HD800’s for instance). And it’s simple physics that prevents it from happening in an IEM as they’re inserted into the ear canal.
In terms of separation, timbre, neutrality, mid range and treble quality. I’ve found the Golds to be the best i’ve heard and for me, with a better soundstage than for example the IE800 that a lot of people hail as the best one of the best in this area. Only the Shure KSE1500 offers improvements in much of these areas, but has some disadvantages too.
Looking at review of the Acoustune on Headfonics, where the Flares Pro was compared. I’d say the Gold and 2 HD are a decent step up to the Pro and it would have outdistanced the Acoustune on a number of counts, including the soundstage, imaging, etc.
