HiFlight
Please feel free to check my IC listing for my Golds on the F.S. forum. If any interest, please contact me via PM.
Thanks..
Thanks..
Thanks..
@Arysyn think some of the tuning problem with the Unique Melody Maker planar has to do with what else they are trying to do with the design. Found this in a Head-Fi review. A company official starts off with:
"A planar driver’s ability to move air, even with an open design, has led us to believe that we need to find ways in which to normalize the pressure within the ear canal, which allows a more natural sound reproduction compared to if the canal was sealed off.
Glass Monkey: Does this mean that what your ME.1 is doing is leaking out the harmful low-frequencies that cause resonance and stapedius reflex? Basically, killing bad vibrations.
Lawrance: Yes, and at the same time, it’s an acoustic filter that attenuates the outside noise at specific frequencies."
So they are intentionally leaking some to reduce pressure in the ear canal . That has to affect bass response. Then they are attenuating some outside noise more than others. This isn't a straight "by the book" planar design.
That is mostly what I used with them, streaming Tidal and Spotify. Great synergy and stunning sound! The Amp5 is a most worthwhile addition to the DX200.
The Amp4 is supposed to be outstanding using the balanced output. You can easily do that by using the little MMCX adapters I mentioned in a post earlier on the Pro thread. Cost is only about $18 and they allow the use of any balanced cable with the Pro or Gold. If you can't find the post, I can PM you with a purchase link. You would also need a 4.4 to 3.5 adapter for use with the Amp4.I was afraid you'd say that. I'm currently listening to the DX200 with Amp4s with the Golds streaming Tidal. Not giving any impressions yet, just burning in, but I will say it is nice to not have the volume at 90-100 just to listen at the office.. I was thinking that Amp5 would be a good match. But I bought the other amp instead, not really intending to use it with the Golds.
Good luck, I hope your sale goes well.
Someone in the Hiby R6 thread mentioned the Pros had great synergy with the R6, in case anyone here was wondering.
YES!!! Exactly!Or how about a little something like this?
YES!!! Exactly!
You use foam eartips?
Nothing wrong with that, just isn't my preference, adds too much bass. I use the Spinfit TwinBlade, large. I'll see about taking a photo of my setup.
Ok, Story Time! Sit down and grab a cuppa!
I ordered the Flares Gold just when my German inlaws came to visit. For the first week, I used the silicone tips Flare provides (Pro and Gold tips are interchangeable), but I never really got a chance to get a good listening session in while they were here. During this time, I felt largely uninpressed with the Golds and seriously considered returning them. Then, in the midst of a bout of bronchitis, I realized something.
Flares provide sublime passive isolation, but not, it seems, for my wife and her family. Not that these people are loud - far from it - but it is more that they are able to speak in such a way that I know they are there and I cannot get any critical listening in.
I remembered I'd had good experiences with foam tips providing better isolation on Roxanne II, so I got some Comply foam tips to help drown out the family. Then, I thought I'd be able to get some good listening time in.
It worked. I was able to hear the differences between the Pros and Golds and realize that I strongly prefered the Gold tuning over the Pros.
While the inlaws remained, rather than switch out for the stock silicone tips every day, I've just kept the Comply foam tips on. Although the inlaws have been gone a week now, I'd gotten so used to the foam tips that I haven't switched them out yet. I will soon, but I've been lazy.
Now I have ordered extra tips - mostly silicone - from Flare for the future. Yet, I made sure to get an extra set of foam, just for when the inlaws visit next. They come twice a year, so I may have need of those foam tips for some time to come.
Full disclosure: my inlaws are actually great. They're helpful, the kids love having them around, and they do a lot of the tasks around the house which saves me from doing those instead. Still, it's nice to be able to lose myself to music from time to time. Maybe you know what I mean.
Thanks for reading and I hope you enjoyed your tea!
