Arysyn
You're living in much better country than I am if the store is willing to give you a refund or trade for burned-in OLED. In my location, OLED burn-in is your problem, not the stores and you can't do anything about it. I'm very careful with OLEDs anyhow, and my current LG B7 has built-in mechanism for preventing burn-in from happening - the whole picture moves 1-2 pixels to the left or right every couple minutes (you can't see it, but hopefully it works).
Anyway back to the subject - I didn't mean "burn-in" as some deliberate process, I just meant that after let say 200h of heavy use, the sound of Flares PRO becomes more polished in upper midrange. By heavy use, I mean listening to music at least several hours a day, but I'm often leaving them playing music through the night to speed up the process.
Also, there's one other issue related to burn-in. I've noticed that some IEMs (dynamic ones), left unused for a long period of times, sound different than when used often. So the burn-in might also be just frequent use and after long idle period you need to let them play a while, for them to sound good again. Just a thought.
Burn-in and burn-in are two seperate things for screens and audio equipment. For screens, burn-in means image retention. Obviously that can't happen to a speaker.
Burn-in for audio gear means, for drivers for example, the materials loosen up from their first movement until they reach an average pliability - the driver suspension, driver surrounds etc. In electronics, capacitors can also change property to their intended ESR values etc as the dialectric settles in to the patten of electric charges it experiences. Some people claim burn-in for other things but this can also be simply the brain getting used to and normalising a sound character or placebo too.
The two are not related to each other, it's just the same words to describe two different things...
I think there would have to be some problems with materials used in drivers for them to require burn-in after not being used a long while (unless they're being stored in a different temperature, like cold storage). That change in physical property would probably age the materials and cause premature failures. Manufacturers would be aware of those effects and not use those materials.
Personally, I would put the sound difference down to one's brain normalising one sound and then moving over to another that has a different frequency response and slowly normalising that one. If you listen to something with a suck-out at 5kHz, it won't take long for your brain to normalise that and for it to start to sound normal. Then when you move to something with flat response, your brain's compensation will make the flat response sound like it has a 5Khz hump... until that flat response becomes normalised. Each time to you listen to the heaphone, you will be subconciously expecting for it to sound a certain way.
To begin, its great to see this thread active again with various information and discussion of it. I'm going to post something I received from Flare, which will be in a separate post from this one. Yet first, I'll respond to some posts written here...
I realize of course the meaning and the intent of the Burn-In suggestion, being to allow random audio to play through a new iem for several hours, in order to allow the iem to adjust/to get its tuning operating normally, etc. I made the connection with other types of Burn-In based from the interest I have in how they relate in unique ways that still maintain the key differentials. Burn-In on a tv is not an action, such as with an iem where Burn-in is the act of allowing audio to play for a long time essentially to improve the audio to its "normal" state. Whereas Burn-In on a tv is the visible remnant of sections of picture engrained into the display.
However, there is a connection in the nature of how both involve something playing on the particular equipment associated with its form of Burn-In. Similarly, they both cause alot of debate. Some people refuse to believe burn-in actually exists on a television, despite evidence, meanwhile the same occurs in the debate about burn-in with audio as an effective action to help bring the sound tuning to its normal intended state.
My interest being in the unique attributes of those, is why I mentioned them in a way I realize may still have been unclear to my own intentions, so hopefully this explanation helped to do so. Also, I live in the suburbs of Chicago, Illinois - which has some independent electronics stores left with competitive warranties that will cover burn-in. Actually though I was surprised when the store said they'd take the tv back, because of the reason I heard others online say they can't get a return/replacement for. I'm actually going to try getting a replacement with a newer model tv, but an LED instead of an OLED. I'm waiting a few weeks to see what Samsung will announce of their supposed FALD QLED tvs this year. I'm also in need of a new smartphone, so I might try getting the same brand of both for better interactivity, such as remote connections.
Anyways, I'm still figuring out how to best display the letter I got from Flare, which is a public announcement read it looks like, they sent to me as a pdf. I'm still working through some ideas with them where I can help them, and get to listen to the FlaresGold without them taking a loss on the product if I return it for the upper treble reasons, if they carried over from the FlaresPro. I'm thinking something like a review unit I could listen and return, which I agreed to cover the return shipping costs, or similarly with a prototype with the same exact tuning. I'll see what they say about it. I'd love to be able to give it a review here on Head-Fi finally.
