Jonasklam
- Nov 26, 2009
I tried the Buzz Player very breifly, so far it seams pretty cool. You can even delete the files you copied over on the iPhone itself and I does play a lot of movie formats aswell.
I figured out how to add album artwork, but it can become a PITA. What you have to do is rename a pic of the artwork to whatever the album is called and just drag an drop the same way you do for audio. The problem is that when two albums share substantially similar names, such as Zeppelin I, Zeppelin II, etc, you have to add the last one first. For example, I have Zeppelin I-IV, so I had to add the audio for Zepp IV, then the pic, then the audio for III, then the pic, etc. If you do it the other way around, all of the pics will be filed with the Zeppelin I album and nothing will sync with the others.
Also, every once in a while the audio playback goes a bit wonky, like a cd that is skipping. Anyone else experience this?
Wow your not kidding, it can be a PITA. Takes time but oh well. What I am still trying to do is have it shuffle. I have created one large play list, but at best I can only reorder the tracks. And I find that the only artwork I will see then is one that I have renamed the same as the play list. Any suggestions. But I will live with this if I must as I do enjoy the better overall sound.
pfl....
I'm really curious to see if this app is worth $10. Anyone had buyer's remorse yet?
I have none, though the app could definitely be more user friendly. I bought it mostly out of curiosity and it does play flac, which is really all it was made to do. I guess worth comes down to how much you would pay to play flac on your ipod.
ALAC and FLAC are both lossless. There's no way you'll be able to ABX it. Purchase this if all your music is in FLAC and you don't want to transcode, or you prefer the drag and drop instead of iTunes syncing.
wazzupi said:/img/forum/go_quote.gif
no basically connect your ipod to itunes click the specific music player *ipod touch/iphone whatever* and click on the apps tab which is located on the top left closer to the middle of the screen if that makes sense lol. then look down where it says buzz player on itunes and click it then you can add all your music and movies to it by clicking add. and you are done XD.
