KaminKevCrew
- Jan 22, 2015
The point of the Adel module, according to Stephen ambrose isn't so much that it's adjustable for different sounds as it is that it's adjustable for the stiffness of your eardrum. You adjust it so that the membrane can compensate correctly for the stiffness of your own eardrum. If the membrane is too stiff, the Adel module might as well be fully closed. If the membrane is too soft, it doesn't actually do anything beneficial; it ends up removing some sounds and ruining the listening experience because it absorbs some of the acoustic response of your eardrum.
