Swampwalker
- Oct 28, 2003
IMO, with a high quality source and some good NOS tubes, the microZotl is right up there with the best. Outshone my older HR Max driving 600s and 650s.
Originally Posted by OakIris Still trying to find out which amp is recommended for use with a computer sound card - I think it is a given that a good soundcard is needed. (I may be upgrading my card to an EMU1212m. Head-Fi always makes me spend more money than I planned to - yesterday, I really only wanted a new pair of headphones.... |
Originally Posted by OakIris And do you need a DAC as well as a headphone amp? |
Originally Posted by OakIris gsferrari - I'm still having some trouble with this 'use a DAC and bypass your computer sound card all together' concept; please bear with me! So, I would (presumably?) remove the sound card from my computer system. The Xitel would then be connected to my computer via a USB port. But what is the connection between the CD drive on the computer and the USB port and then out to the DAC? I already use digital audio playback with my CD drives, which means they aren't physically connected to the sound card with an audio cable; if the sound card is gone, does Windows just automatically send the sound signal to the DAC? From what I read on the Xitel site, you are then supposed to connect the DAC to your home stereo system. I take it that instead, I would connect it to a headphone amp and then plug my headphones into the amp. I must say, that if a $99 DAC can equal or exceed the performance of a $200 sound card, I'm all for it! |
Originally Posted by erikzen I'm not sure if gsferrari made it clear to you or not but the simple answer is that if you're using a good soundcard as a source you do not need to use a DAC. You can run an IC from the line out of your soundcard to an amp and then plug in your headphones into the amp. If your soundcard has a digital output, you can add a DAC to your system if you so choose. This should help you squeeze out the last bit of sound quality. You'll need to have the proper interconnect depending on the output of your soundcard and the input of your DAC. From the DAC you then run the signal into an amp or you can buy a DAC that has an amp built in. |
