gsferrari
Member of the Trade: Veda Audio Contributor
- Nov 10, 2003
Done
(darn the stupid 10 character limit
Originally Posted by OakIris gsferrari - This is a good thread - helps almost-newbies like me, too! Just curious - would a computer soundcard be equivalent to the low end sources listed in your $$-Fi section? I'm considering getting a new amp for my computer set up. I'm already using a Meta42 amp. Are there better amps to use with a computer soundcard? (I use an M-Audio Revolution, but I may upgrade that, too....) |
Originally Posted by gsferrari If the sound card has an optical out or a REAL line out then it would classify as a $$-Fi source. But it needs to be a rather nice sound card or at least an external DAC like the Xitel ones... www.xitel.com |
Originally Posted by fewtch Good idea... M-Audio Revo, Audiophile, Terratec EWX (and cards with similar design/chipsets) should be a 'minimum requirement'... Soundblaster Live's got to go (in the trash can) Also, in my opinion all soundcards should be amped for much better SQ, even if they have a headphone jack. Same reason that people use 'line out' to a quality amp from standalone gear rather than built-in headphone jacks... they just aren't very good quality. |
Originally Posted by Spent&Bent Aside from the EMP thing already mentioned, I don't think the RA-1 should be placed so low, I'd give it at least a mid level position / rating, after all it was designed for RS-1 / RS-2 and IMO deserves something better then entry level, also you'd be spending far too much on such an amp compared to the phones etc. |
Originally Posted by fewtch I object to the "Low-Fi" "Mid-Fi" and "Hi-Fi" classifications. This is not the way these terms are commonly used in the audio world, and I think it would just confuse newcomers. E.g. if Grado SR-60s are "low-fi," what does that make a pair of cheapo Coby earbuds (No-Fi? Since an objection should come with a suggestion, how about "budget hi-fi," "midrange hi-fi" and "ultra hi-fi" (or something similar to these terms). |
Originally Posted by gsferrari The problem with the RA-1 is that it is a glorified op-amp based amplifier which competes with the PPA as far as price is concerned. But it is a no-contest with the PPA as far as performance is concerned. Which is why I put it among the rest of the op-amp based amplifiers in the $$-Fi |
Originally Posted by fewtch Good idea... M-Audio Revo, Audiophile, Terratec EWX (and cards with similar design/chipsets) should be a 'minimum requirement'... Soundblaster Live's got to go (in the trash can) |
Originally Posted by tortie Isn't the PPA also op-amp based? |
Originally Posted by gsferrari The problem with the RA-1 is that it is a glorified op-amp based amplifier which competes with the PPA as far as price is concerned. But it is a no-contest with the PPA as far as performance is concerned. Which is why I put it among the rest of the op-amp based amplifiers in the $$-Fi Also - it is in the company of the Gilmore Lite I dont think anyone should be ashamed of the $$-Fi - just because the $ count is low doesnt mean it is a bad setup. I have heard some $-Fi setups that are better sounding than a few $$$$-Fi setups |
