I am listening to my HD600s right now through the uDAC with an upgraded cable; I also have tried my HD600s with my iBasso D4. I think that both amps are are underpowered with the HD600s; having said that, I think that the D4 amplifier does go a bit louder than the uDAC with the 9v on, but not by much.
To me, the HD600s can sound fatigue-ingly bright when not used with the right amp, and I do not have this issue with the uDAC at all. And it gets plenty loud for most listening.
So the uDAC also has better synergy with the HD600s IMHO; the D4 has more of a "reference" DAC in it, while the HD600s sound more musical to my ears with the uDAC. If you don't need to go portable, there is no 9v battery to replace on the uDAC. But there is no way to get full amplification out of the D4 without one, even when it is connected to your computer.
The D4 will also work with your iPod for portable use with the 9v battery, while the uDAC will not go portable at all.
So although they may appear so as small DAC/amp combos, these are really not directly comparable products and your intended usage should ultimately guide you.
Get that rca-1/8" cable! You will hear a huge improvement, then use the uDAC as a DAC/amp until you can get a real amp, as the uDAC scales up nicely. But so does the D4, and without the battery.
Try plugging your headphones into your Creative T20s' headphone out, for "exercise"
Originally Posted by drizek /img/forum/go_quote.gif Just put an order in. Can anyone compare it to the iBasso D1/D2/D4 using the HD580/HD600? I am wondering if it was smart of me not to buy one of the iBassos in the first place. |
Originally Posted by drizek /img/forum/go_quote.gif I just wish it was possible to have them both plugged in at the same time. I let my headphones run when I am using my speakers because I figure it gives the drivers some exercise. When I use headphones I just turn off the speakers. With the uDAC I will have to plug the headphones in and out every time I want to use them. That is kind of annoying. |
