Well as the saying goes your chain is only as good as your weakest link....
Sure is...
Do you think NEC USB controllers are best out of the ones you have tried??
I remember you were looking at some Korean made Audiophile USB card....
You mean like the ones found in different USB cards?
Yes I am tapping directly off the mobo with a 6inch usb cable to the Audiogd DI. I wouldn't mind a good pci card for usb. I'm going to have to add that to my list of must-do tweaks.
