First of all, thanks to Charles for his warm welcome on the "Casques-Headphones" stand, and thus the listening of the following 2 models (there were others) at Fir :
- FIR Audio KR5 (3000$)
- FIR Audio XE6 (3900$)
Dap used M1s, 2.5mm balanced output, fast filter, low gain.
Unknown" tips, black, silicone, medium bore (neither wide nor narrow) supplied by "Casques-Headphones", but which did the job (sal and fit = RAS).
Stock cables, symmetrical. I'll talk about it again...
ATTENTION:
I don't know which modules were installed! Silver ? Gold ?... DK...
Disclaimer:
What I'm looking for in my hifi listening, are products whose general behaviour, the sound, is as close as possible to the sensations of live. It has to be lively, as dynamic as possible, with nuanced transients (from murmur to extreme violence). I'm not interested in whether it's "neutral" or "straight" or "transparent". What I'm looking for is balanced and homogeneous products, both in BP and in texture. I'm also interested in "definition" and "resolution": it has to be as high as possible, but still natural. It's like a TV with too much or too little sharpness. You have to find the right gradient. So I like products that are "on the edge". You also need substance, harmonic richness. I'm not interested in overtly analytical sounds... because they are not realistic. The same goes for the opposite, when I think it's too "round", or too "hot", or lacking in "sparkle" and "bite" (these are purely musical notions by the way). The stories of "musicality" also seem completely abstract to me...
In short, this is what I'm looking for. If a recording, a song, a track is aggressive, then it should sound like that. If it's soft, then it should sound "soft", if it's... we get it.
FIR Audio XE6
Well, I'll start with this one... which is not my thing, but it's good. Let me explain.
It is a bias, and I would say that it is the "BASS-HEAD" version of the KR5... which already have everything of the intra BASS-HEAD iem !
To be more precise, it's rather the "HIGH-GRAVE / LOW MEDIUM HEAD" version .... An analysis between the Kr5's and the XE6's shows that the tuning of the medium and highs is different. This is how the balance is changed, on an identical or almost identical bottom end bass tuning :
Illustration:
And so, when listening, the psychoacoustic balance is quite profoundly modified... Compared to the KR5's, the XE6's are clearly "warm", and for my taste too much so. This does not make me run away, but I feel a strong coloration, which I hear on each track I listen to... So a lot of systematism, which in my book is not a good thing, and in any case, not something I'm looking for.
I've listened to all styles, and it was confirmed each time.
After that, having said that, it's a nice, fun listen, obviously, very solid sound. Their "Kinetic Bass" system is not a gimmick and it works very well (also by virtue of the tuning) = it's telluric, very physical, and it gives quite unheard of sensations for iems. At the same time, as it is an open structure and radiates directly into the conch of the ears, no discomfort or unpleasant acoustic overpressure. In short, for me, their concept works. And the phonic isolation isn't very good.
After that, as I read on the net, is it on the level of the best headsets, or better... of a somewhat ambitious sedentary system (let alone the best) = no way. Sorry, it's not going to be for this time! :loool: Don't push granny in the nettles, and frankly, the people who post this on the net, I wonder what their references are !
So if I summarize: colored listening, big bias in the low / low medium bandwith compared to the rest of the audio spectrum, while being alive, detailed, very powerful. Homogeneity perfectible amha, between the impact of the bottom / bass very important and thus, the armatures in the top bandwith which well... sound like armatures (tones, timbres), and thus according to the tonal balance chosen and claimed.
In summary, glass half empty and half full for me. To try, I think, before purchase.
Oh yes also, the stock cable is... dispensable... but I think that for the XE6, it is however more indicated than for the KR5. See below...
FIR Audio kr5
This is an almost completely different beast, and to tell you the truth, it looks a lot more like my stuff (sound wise)!
Big bass, telluric too, etc., lots of rumble (I don't think I've heard such a marked effect elsewhere for iems, but under control). The lower midrange is a bit too forward though, which introduces a noticeable coloration, but way more discreet than with the XE6's.
Where this changes is in the midrange and what follows: it is crystal clear, with total clarity (rather than limpidity), with a very high level of definition and resolution. A lot of bite (maybe too much ?). Without worrying about the Final A8000's, which in this matter are my references, with the Rhapsodio Infinity mk2's.
A word, for the restitution, in general:
IN-TEN-SE.
In my book, more intense than what I knew of more intense, that are the Kaiser Encore, the Final A8000's and the mighty Infinity mk2's !
But....
It's borderline foul amha. I've listened to these beasts about 20 minutes, and I was starting to feel a fatigue.
Also, it's "over spectacular", but it lacks naturalness (timbres) as everything is over the top. Compared to my Ringo's not to mention them, this is very obvious. Where the kr5's are "crystal clear" at the top of the bandwith (from the midrange and then above), the Ringo's are far more "limpid", more liquid, but just as detailed. Also fuller, compared to the voices for instance, where the kr5's are a bit "thin" (compared to... direct comparison as well). Also the KR5's use the same artifice as the Encore's again around 6-7khz with an emphasis (admittedly more discreet than the Encore's) but which is immediately peerceptible with this test range :
In the intro, there is a kind of bell (?). Now, when the 6-7khz zone is "emphasized", it is immediately noticeable on this bell-like stroke (presence in the mix, supernaturally long decay length, (over-)brightness...).
And so the Kr5's have this trait, like the Kaiser Encore's, the Zeus XRA's, the Final A8000's, the Rhapsodio Infinity mk2's...
Also, the homogeneity of the bandwith and blance is not perfect imao, in the sense that the kinetic bass play in their corner (but what a corner !!! ), then the "rest", with the tuning that belongs to them so...
In short, I found that it tends to "sting"... but it piqued my curiosity, as I love this type of extreme product, which behaves like F1 cars, and which must be tamed. These are my favourite products, and these KR5's (apart from the **** prices), from a purely sonic point of view, are among them.
It would thus be necessary to play with the tips (however, those used at the time of my listening seemed to make the job)... but especially with the cable!
Because the stock cable tends to be thin and harsh sounding, and, I find with the kR5's, aggressive. With the XE6's on the other hand, I would say that the same cable gives off their tuning, much warmer and uh... "fatty", so it's debatable.
But, having in hand my Plussound GPS x8, which is a pure gold-plated silver with just superb timbres and tones, a great smoothness (too much with the Ringo thus...
) and a lot of matter, texture, weightn in particular in the bottom bass end, and with full mediums, hyper natural, and finally very extended but soft highs in short...
... I put this GPS x8 in place of the stock cable and frankly, it had nothing to do with it. Going for the much better, "compared to...".
Conclusion :
Here, here, in a few words my few impressions, in relation to two products which marked me, but with a very clear preference for the KR5's which correspond much more to my tastes.
For the latter, I had the sensation of F1, repeat, very demanding products, but which can give the best if one takes the time to break their code and to understand them.
On the other hand, remain the prices (although the quality of manufacture, construction, finishing are at the top of the top. Also, small shells, very good fit, RAS (Y) )... which are completely ****ed amha... but hey, that's the life....
That's all folks !
