Fir Audio Thread - Discussion and Impressions
Nov 9, 2022 at 12:47 PM Post #3,272 of 6,210
Nov 16, 2022 at 2:23 PM Post #3,274 of 6,210
I always find it fascinating how different the perception of sound/earphones can be depending on person.
I thought about it when I saw the amount of hype surrounding the Xe6 and then I listened to them.
Nov 16, 2022 at 2:27 PM Post #3,275 of 6,210
It's a long time since I used the stock cable but my memory of it was everything sounding a little veiled and congested.
Any cable with a price of, for example, over $100 will be better than a stock one.
Nov 16, 2022 at 2:31 PM Post #3,276 of 6,210
For example, Linkin Park......
The first 4 albums sound better and better, then, when metal and rock evaporated - it's great. However, when we're talking about something like "A Place for My Head", these aren't the IEMs I'd choose.
Nov 16, 2022 at 2:35 PM Post #3,277 of 6,210
Hello, thanks for the review, I am getting torn between the Traillii and XE6, if you had money to buy only one what would you choose ?, I am into mostly pop, edm and dance music. I know this is a Fir Audio thread, but I would appreciate a honest recommendation. I need something which would get my feet tapping, I currently own a Mext and enjoy its musical tuning, so looking for an upgrade.
For light energetic genres, the Xe6 will be a better choice if you need an emphasized bass.
Nov 16, 2022 at 2:35 PM Post #3,278 of 6,210
Some stock cables cost over $1000. That's a bit of an oversimplification.
I've tried a bunch of expensive cables on my Kr5. I prefer the "cheap" stock one. ymmv
Nov 16, 2022 at 2:40 PM Post #3,279 of 6,210
Does anyone have any impressions of the sound difference when using the various atom modules on KR5? - curious to try, but they look a bit of a pain to change!
I have, but on Xe6.
There are many of them, but, unfortunately, the impression of the replacement cannot be conveyed in censorious words, even taking into account my authorial past.
Nov 16, 2022 at 2:41 PM Post #3,280 of 6,210
Obviously I'm talking about the stock Fir Audio cable.
But it's good, because upgrading the cable is a slippery slope... Changing the IEMs still gives more effect.
Nov 16, 2022 at 3:05 PM Post #3,283 of 6,210
Rather not true in case of FIR's stock cables.
Scorpion is quite good, better with Xe6 than i.e. Forza Hybrid, PW No.10 or Dunu Hulk.
Around $1000 - the difference could be audible - LL Venom, Erua Tawa.
But below it would require a lot of hunting to find a better one than Scorpion.
Nov 16, 2022 at 7:20 PM Post #3,284 of 6,210
Nov 16, 2022 at 7:24 PM Post #3,285 of 6,210
LP with XE6 “works” but there’s IEMs that work better for that sound/genre for less money. You don’t need an XE6, or any of the frontier IEMs for that.
Musically or technically, they really don't need anything incredible. I enjoyed them on CA Solaris SE, CA Supermoon. However, does it sound better on the Traillii? Of course, yes.
