Found the same to be true for Tool, A Perfect Circle, puscifer,Daft Punk and especially the Beatles. .Flac or .Wav for pcm, nothing less is acceptable.
Exactly
I love those bands
I really understand how MP3 is not enough for metal.
Sorry George - this might be a blow to you. DR (Dynamic Range) database. First up Haggard - terribly over-compressed.
http://dr.loudness-war.info/album/view/18309
http://dr.loudness-war.info/album/view/18310
http://dr.loudness-war.info/album/view/29545
http://dr.loudness-war.info/album/view/29544
One track on the last album linked is mastered OK. Most of these are lossless BTW.
Escape the fate - one word re mastering comes to mind - terrible
http://dr.loudness-war.info/album/list?artist=Escape+The+Fate&album=
Some Wintersun on Vinyl is OK (impossible to over compress vinyl - but then you have other issues with vinyl noise
http://dr.loudness-war.info/album/list?artist=Wintersun&album=
For ref (because you mentioned it) here is Krall
http://dr.loudness-war.info/album/list?artist=diana+krall&album=
The version I have of "The Girl In the Other Room" is the 24/96 from HD Tracks - 11-14 on the DR meter. Not the best, but off the charts compare to the other recordings you linked.
Like I said earlier - I am extremely sceptical you can tell wired from Bluetooth (in a volume matched blind test) and especially with those artists - but hey if you insist you can, I won't argue. I'll just remind you of what you said though :
In my experience anyone stating that with the Q5 (same DAC), especially saying its easy, just lets say my BS meter starts to go nuts
Lets leave it at that.
Paul, Think about it the logical way.
First, I was very aware that all the music I listen to has little to no dynamic range. This is what I was implying and trying to say. Stuff that is dynamically compressed is harder to play well, thus requires better equipment.
Krall has a good dynamic range. This means that what is loud is loud, what is quiet is quiet. Things are not sang at the same loduness, so they aren't hard to reproduce.
Just think about it
Low dynamic range means compression., This means lots of things played at the same time, at the same loudness.
What is harder to reproduce, a guitar and a cymbal, each at their own loduness, or 5 guitars and an entire array of drums played at the same loudness, at the same time. The thing is that this poor mastering requires better equipment.
With Jazz, Classical, and Vocal-centric music, except for tonality, things sound too similar. The detail retrieval doesn't help something where details are presented well, and where details stand out a lot.
Now for Wintersun, for example, or Brain Drill, or even softer stuff like Incubus, you get a rain of stuff, energy, life, it doesn't wait for your brain to process it, that is where you'll feel MP3 vs FLAC, as well as APT-X vs normal BT. Try sirenia for example, lots of cymbals over each other, loud noise, no dynamic range, that is where having better equipment helps.
You don't listen to distortion. Metal is mostly distortion, the guitars are based on levels of distortion, this is why I insist on reviewing PRaT and such.
If you have synths, guitars, bass, drums and voices played at the same loudness, at the same time, you're going to have a hard time processing it. MP3 algos erases the synths (usually), along with certain rythm guitars and background voices.
In all fairness, you are a good reviewer, and I don't contradict you. I just am going to hold my position, it really depends on the music you listen to when assessing something.
I volume match and have my girl help me do tests so I can only focus on the differences.
