@yaslam :
The changelog for the latest build of Neutron (2.01.0) states that it does "support native DSD on Fiio DAPs (X5, X7, ...)".
However, when I play .dsf files (DSD64) on the X7MkII, it still says "Frequency: 176400" and "Bits: 64 (out:8.24 int)" under
Settings -> Audio Hardware. Is this only a visual flaw or is the MkII not supported yet? Or are there any specific settings you need to change to make it work?
I also remember you mentioning that FiiO Music uses DoP, but in Neutron, there is no sound unless I activate
Native DSD (which, according to its description, disables DoP) within
Settings -> Audio Hardware -> DSD, DSD over PCM (DoP), which seems a bit odd.
Also, does the regular version of Neutron store any kind of logs that could shed some light on what is really going on here?
