waiting for Fiio X9.
FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Starfield
- Apr 14, 2015
Hi, Starfield
Could you tell us where did you find your songs disappear?
It happens with the storage of Spotify's offline playlists/songs to the onboard memory and the SD card.
I even have to relog to spotify every time I turn my device off.
have you tried the SD card on 200 GB? does it work?
Mooflotic
- Aug 5, 2016
Gents,
I've moved to my freshly arrived AK300 for the time being, if FiiO releases a new beta firmware I'll test it but I'll stay with AK for now.
I fully trust FiiO will supply a wonderful final firmware soon!!!
Soundwise I prefer FiiO (especially with AM3) but the comfort of AK app is a bit better.
JeremyLaurenson
- Jan 3, 2011
Gents,
Let us know!
Hi, 2damoon
1. Could you tell us where you found the files disappear? From the folders or the playlists?
2. Please try to uninstall the X7 in device manager and use another USB cable to see whether it helps?
Hello Fiio,
1. The files dissappear from the Playlist, not storage. If I do a rescan, they all appear. It happens sometime that all disappear, or just some.
2. I tried everything I could think of. The device does not show as Fiio in the Device Manager. It shows as unknown. I tried uninstalling it, installing it again, reinstalling the software, using different USB ports (I am using the same cable and port that worked in the previous firmware) and nothing makes it appear in Device manager as Fiio, and of course, because of that it does not show up in Fiio Control app.
Starfield
- Apr 14, 2015
Also, is there any way to merge internal storage with the "nand flash"? Separating internal space this way is kinda bad, since some apps can only be installed into internal storage, which has less than 1GB.
Hello Fiio,
Another issue I have discovered. The names of the Storages are messed up to. The Internal Storage is now called "SD Card" and the SD Card is called "TF and a Chinese character"...lol...this is messed up...
JaviAl
When seeing an album on library or artist->album does he order it acording to ID-TAG "Disc Number" if exists?
I don't check if does.
apaar123
- Sep 10, 2016
Should i buy this without a amp dac or a cheaper dap with amp dac
warrior1975
- Dec 5, 2013
Glad to hear Viper is still big in your system needs. If I ever have need I would love to try. Maybe I'll buy an inexpensive Android phone that has decent sound and Root it just to see, might be fun. Any phone that you can think of that might fit that bill? I would use it just as a music player as I'm not going to root my G4, not yet anyway. Cheers.
Sorry just saw this bro. bavinck suggested a fine phone though.
[COLOR=111111]have you tried the SD card on 200 GB? does it work?[/COLOR]
Yes, it works.
Id buy this without a dac/amp. X7 is a great standalone dap. Very versatile. If you go the other way around, you will have a stack, which to me, can be frustrating to carry at times.
apaar123
- Sep 10, 2016
can it power hd600 well?Sorry just saw this bro. bavinck suggested a fine phone though.
Yes, it works.
harpo1
- Dec 1, 2014
apaar123
- Sep 10, 2016
i might use fiio q1Yes with the AM3 or AM5 amp module.
apaar123
- Sep 10, 2016
Does it have aptx?
Total: 31 (members: 0, guests: 31)
