Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
So there's a sale on some Beyerdynamic DT880 premium (600 ohm model) and i heard these are tough to drive. I know there is a 250 ohm and 32 ohm model too but the 600 ohm should have the edge in sonics. Can anyone comment if the medium AM2 amp module will drive these to their full potential? If not will the high power amp module AM3/AM4 (forgot which model it's called) or the K5 dock will do better? Anyone have these DT880 and paired with their X7 ? Thank guys.
I just went through the (lengthy) decision of which to go with: DT880 32 ohm vs 250 vs 600 ohm and settled on the 250 to strike a balance between drivability vs sonics.
The K5 will do better but the K5 won't even drive the 250s to their full potential let alone the 600s.
Do they sound good ? Yes, however the wide variations in program material volume make it challenging without a lot more gain. I just returned the K5 because it doesn't drive my 250s any better then a Duet 2.
During a conversation (yesterday) with Paul from Beyerdynamic US, I asked what power he thought be sufficient - he felt it would take near .5 watt to drive the 250s properly.
I'm inclined to believe that with my experience thrown in and my desired listening levels.
Without going into the whole hearing protection issue I believe you can get to satisfactory listening levels with the higher powered Fiio amps with some program material - driving to their full potential? Not so much.
Well that's disappointing to hear. I'm not a loud listener but I would like to hear the DT880 on their full capability sonic levels. If not the K5 or high power X7 amp module do you think an JDS Labs O2 would be enough juice? I think the K5 are rated 1.5W (32 ohms). Not sure how much mW I'll need for these DT880 at a modest listening volume. I usually listen on my X7 on high gain on my NAD HP50 (32 ohms) only around no more than 60 depending on material. Also heard tubes paired the best with DT880's but not sure if any truth.
We are on very similar paths just now.
The 1.5 W at 32 ohms is just that - so you'd want to look at the rating closest to your headphone ohm rating - so at 300 ohm for the K5 is 150 mw or one tenth the output compared to 32 ohms - if I'm doing the math correctly. So even less for the 600 ohm.
I had the NAD HP 50s and they're A LOT louder than the DT880s out of any Fiio product. ( except for the 32 ohm version but the NADS are still more efficient)
I have zero experience with tube driven headphone amps and, like you, have been reading/hearing much about the benefits.
I did ask Paul (from Beyerdynamic) to share his thoughts about tubes vs solid state.
His opinion was that: if listening to vinyl on some high end gear, then tube equipment would/ could surely enhance the experience.
For digital listening solid state is a great choice.
So of course, it's better if we could simply walk in a store and hear all these products for ourselves and gather our own thoughts but for now....
The JDS Labs 02 is not quite as powerful as the K5 or very close.
600 ohm rating is only 88 mw -
I'm actually considering the Schiit Asgard which has a 300 ohm rating at 380 mw and 190 mw at 600 ohm - reasonably priced - substantially more output than K5
Sorry, PapaThrust--where's this Paul you spoke with? I would love to have a word with him. Usually we are a diplomatic lot and do not take to disagreeing with representatives of other companies lightly, but in this case I don't see the harm in it--not least because Paul would seem to be contradicting official specifications data on the DT880, which lists a power handling capacity of no more than 100mW even for the DT880-250 PRO version. One should note that with a nominal sensitivity of 96dB/mW, the DT880-250 would reach an ear-splitting 116dB with 100mW input, so it's no wonder that they may start falling apart above that level...
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
