x RELIC x
i think the AM1 module really holds back the full capabilities of the player/es3018s DAC.
Correction - ESS9018S DAC.
It is around 95mm in diameter.
i think i just half confused the cpu and dac chips :')
Hi all, sorry the newbie question ...
The X7 line/coax out is beeing used for external AMPS, right? the DAC is still the X7 ESS9018S ?
Or is it just a digital source for use with an external DACs/AMP ? if this is the case them why use a pricey source like X7 instead of a cheap alternative?
Regards
Regards
As CH23 has said, for the line out yes, for the coaxial out no. Line out bypasses the amp, and coaxial out bypasses both the DAC and amp.
Thanks CH23 and RELIC!
So as I understood the top connection on X7 has both roles, an analog for an external AMP and also a digital for an external DAC (With or without AMP) ? so now it makes sense for me the setting option of the "multifunctional" Output ... Lo for an AMP and coaxial digital out for a DAC ...
Regards
Notice the included coaxial adaptor is a four pole plug - TRRS (Tip, Ring1, Ring2, Sleeve). The bottom two poles (Tip & Ring1) are for the left and right (+/-) stereo signal, the third (Ring2) is a shared ground, and the fourth (Sleeve) is for the coaxial signal. When using coaxial output the Tip and Ring1 are ignored, and when using the line out the Sleeve is ignored.
Many thanks for the info!
Now I'll make that silly? question:
If I stick accidentaly my in ear phone on that hole I should still listen the analog signal at a very low level and without volume control?
Regards
Regards
Don't do that.
It'll blast your ears.
Not sure if this has been mentioned previously...
Can someone please clarify What is the max bitrate output of the coaxial digital output?
Thanks.
