PapaThrust
No problems at all with 200GB card.
Eh - What card are you using? Pc or Mac?
There are some of us having problems - trying to get Fiio on board with some specifics.
I'm using a Mac and Sandisk Ultra is buggy.
Purely out of interest, has anyone found an amp that (physically) stacks nicely with the X7?
I'm looking at the Sony PHA2 - only because the size seems like it will stack well..
FiiO X7: 64mm x 16mm x 130mm
PHA 2 : 68mm x 29mm x 140mm
Although, I don't think the PHA 2 has a coax input, so it would likely be a 3.5 to 3.5 connection. No biggie.
Also have never auditioned the sound from the PHA 2.
EDIT: Also, the Oppo HA2 is pretty close as well, and would look awesome.
The Neco Soundlab v4 is a chunky thing so actually stacks very well with X7 and sounds superb.
Plus you can select improvements from basic model.
Coming soon: XTZ Headphone Devine)
How and where are you setting a power off timer and how is it not being observed?
Is it via Android settings->Powertimer->Idle poweroff?
Is this problem only when the X7 is plugged in or also when it's on battery power?
Originally Posted by Sonic Defender /img/forum/go_quote.gif
I would e-mail them at XTZ to make sure it supports WMA. It probably does, but worth finding out.
It may also explain why I have NO problems with my X7.
I take that back--maybe just a little bit.
The problem with the pause button not UN-pausing when the display screen is off extends to BT Headphones, too. When you use the pause button on the headphone, it won't un-pause if the screen has been off for awhile--until you turn the screen back on. (Same with BT Headphones that pause automatically when you remove them from your head.)
Another complaint I have is the the lack of TIME REMAINING indicators.
And there's no indication of the total time of an album.
For individual tracks you can make a wild guess according to the blue band moving across the screen as to how much time is remaining, or go to the Track Info screen and get the total length of a track, then go back to Now Playing and subtract the elapsed time and...(If I'm missing something, please let me know.
I'd like to see time elapsed at the left end of the blue band and time remaining at the right end. OR, tap on the time digits in the middle and have it toggle between ascending or descending time. It seems like a fairly common thing to have. Us busy lazy bums have to be able to manage our time more efficiently.
I'm also having Idle power off. In both Pure and Android modes the Idle Power Off action seems to be random, I have it set to 10 mins and the system either shuts down while it is playing or fails to shut down when it is is idle.. The X7 is connected by coax to a Chord Hugo but neither are connected to power.
